1994 cosa 200
Vespa cosa 200
Sat Jun 01, 2019 12:51 am quote
Hey guys and girls,
Past year just before summer i bought a cosa 200
In the beginning i was not planning to do big changements to it just drive it and enjoy
But after coming home with it the fuel line came off so decided to put a new one.
At the same time i decided to clean the carb
And there i did my firts mistake.
When starting the scoot it would go to high rpm instantly and throttle was not responding like it should.
After ascing here and on an other forum poeple told me i bended the carb by overscrewing it
So took the carb back off and put it on a glass surface and yes it was bended.
So took some sanding paper with olil on and started flatting the carb on it with succes.
Vespa cosa 200
Sat Jun 01, 2019 1:00 am quote
After fixding the carb problem i cleaned the carbhousing
Removed the oil pump and made some new paper seals
Vespa cosa 200
Sat Jun 01, 2019 1:12 am quote
Then i decided to buy an other exhaust because mine was rotten
Vespa cosa 200
Sat Jun 01, 2019 1:22 am quote
Then winter came and i decided to do i full clean up and to make a rat from it
The previous owner had a friend repainting it and he was a pig
Oversprayed things didnt spray good...
First thing i started with where the wheels and the drums
Wheels before:
Wheels after:
With the new tires:
Vespa cosa 200
Sat Jun 01, 2019 1:29 am quote
Then the drumbrakes
The rear brake needed a new cylinder because this one was leaking
So cleaned up the plate and give it a new color
Then cleaned the engine who needed a cleaning
And reinstalled the plate with new cylinder
Vespa cosa 200
Sat Jun 01, 2019 12:23 pm quote
The rear drum
Old paint removed
New paint
Installed
With the wheel
Vespa cosa 200
Sat Jun 01, 2019 12:34 pm quote
Front drum and fork
Before:
The paintwork:
Also bought new shokdampers
Front end finisht
Honda elite
Mon Jun 03, 2019 8:59 am quote
Looking fantastic keep it up and please report more progress
Vespa cosa 200
Mon Jun 03, 2019 9:15 am quote
After that i putted the fork back with a new brake kabel and tacho kabel
And finally started the body
The painter was such a friendly guy he painted almoast everything
Even my frame number
Before:
After
And some other things he was so friendly to paint
Before
After
Vespa cosa 200
Tue Jun 04, 2019 6:58 am quote
Before aging the parts:
After removing the front spoiler i found some rust
So had to remove it
Vespa cosa 200
Tue Jun 04, 2019 7:11 am quote
Some parts after adging:
On this picture there are the 3 steps:
Left nothing done
Right preparing for adging
Middle finisht
Vespa cosa 200
Sat Jun 08, 2019 12:54 am quote
Than had to change the gear cable because it was painted and was touching the exhaust and the cover has been melting
new cable
Vespa cosa 200
Sat Jun 08, 2019 1:00 am quote
Than started cleaning the other side off the engine
Before:
After:
Also decided to buy a new cdi because mine had the earth cable who was getting old
bodgemaster
1963 GL, 1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Sat Jun 08, 2019 2:41 pm quote
Cosa found a good owner.
Vespa cosa 200
Tue Jun 11, 2019 2:12 am quote
Thank you
Vespa cosa 200
Mon Jun 17, 2019 1:58 am quote
Now we start the floor
Before:
Between:
And after some modifying,3 coats of varnish and anti slip tape we have this result:
Vespa cosa 200
Thu Jun 20, 2019 10:26 am quote
The end is near
The handlebar was a little it rusted so decided to clean and unrust it abd give it a new coat of paint
Before:
After:
Vespa cosa 200
Tue Jun 25, 2019 9:52 am quote
We keep on painting
And installing the handle bar + plastic cover
Vespa cosa 200
Tue Jun 25, 2019 9:58 am quote
The exhaust was not coming completely up on the flange so had to modifiŽ it
So decided to cut the flange of the exhaust
I alos had to modifie the side stand because its not really for a cosa.
Had to cut some peaces of and i still need to weld a longer plate to fix the rear screws
Vespa cosa 200
Tue Jun 25, 2019 12:12 pm quote
Some spy pics off the almoast finisht cosa
image uploaden
Vespa cosa 200
Wed Jul 03, 2019 11:59 am quote
Cosa is finisht for 98%
Have to finish a few things and it will be ready
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Thu Jul 04, 2019 1:20 pm quote
Looking good and now you have it running right and everything inside cleaned, painted and fixed. You managed to do the 'aged' paint job beautifully and as a bonus it hides any little flaws. So much better than commercial fake patina. I even like all your stickers, just the right touch.
Now let's have a pic of you riding it!
Vespa cosa 200
Fri Jul 05, 2019 4:37 am quote
Thanks Voodoo!
Tomorrow i'm going to finish the small things that are left to be done and then i will make some pics and a video
Vespa cosa 200
Sat Jul 06, 2019 9:39 am quote
Here are the finisht pics.
The only thing i will have to change is the exhaust.
Its inpossible to get the jetting write
I went from 118 to 140 and still not enough
Vespa cosa 200
Sat Jul 06, 2019 12:34 pm quote
Little thing i forgot to post
Vespa cosa 200
Thu Jul 18, 2019 11:18 am quote
Because it was inpossible to get the jetting rite with the stok carb i needed to change the exhaust.
So i ordered a sip road.
It arrived wensday and i was so happy that i installed it the same day
Saturday i'm going to check the jetting and if needed adjust it
Vespa cosa 200
Mon Jul 29, 2019 9:06 am quote
My choke was dead so had to order a new one.
It came in friday and installed it today
Vespa cosa 200
Sat Aug 03, 2019 4:24 pm quote
Front shock failed after 50km and pinched my brakeline so had to replace all
For the moment i installed my old shock again but will replace it soon
Vespa cosa 200
Sat Aug 03, 2019 4:28 pm quote
Because my brakeline was pinched i needed a solution.
Eather blend the hole and only use the cable
Or find a deacent braided line kit.
And after surching a wile i found an Itailian compagny who made kits for the cosa and not expansiv.
So i ordered it
And after 1 week it arrived
Verry nice kit
Vespa cosa 200
Sat Aug 03, 2019 4:34 pm quote
So today i had the time to instal this kit
I told my wife its only an hour work
Yeah right it took me 5 houres to do this thing
Working on cosa brakes is a pain in the ass!
First remove the old lines
I had to cut the rear line on the both places because the screws where to tide
Removing the clip that holds the rear line in the frame was also fun it was hidden behind crap and would not come off
Vespa cosa 200
Sat Aug 03, 2019 4:36 pm quote
But at the end i succeded
Vespa cosa 200
Tue Aug 06, 2019 12:31 pm quote
Changed the gear oil yesterday morning but i think the old o-ring didnt liked it.
When i drove yesterday the clutch was making more noise then before and this morning all the oil was on the floor
Ordered some new o-rings and oil today
Vespa cosa 200
Wed Aug 07, 2019 2:29 am quote
So its not the o ring that failed the oil leak is my foult.
When bleeding the brakes i didnt closed the bleeding screw hard enough and with driving the screw came loose and al the oil came out.
So need to bleed the brakes again
Rallies Europe 2016   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.3052s ][ Queries: 25 (0.0838s) ][ Debug on ]
