MP3 500 What RPM are you getting to with a hard take off?
Sun Jun 02, 2019 11:51 am quote
MP3 500 What RPM are you getting to at full throttle take off?
I am only going to to about 4,000 RPM with fuzzy washer and 16 gram Dr Pulley Sliders. Thought it use to hit 6,000 RPM on take off.
Just installed new belt and sliders thinking my sliders were worn. Still same RPM range.
Thinking maybe some broken clutch springs.
Sun Jun 02, 2019 3:29 pm quote
6000. Gets there and pretty much stays there until about 70.
Mon Jun 03, 2019 2:38 am quote
That is what I thought.
2016 MP3 500cc Sport ABS
Mon Jun 03, 2019 7:27 am quote
I never go full throttle
Mon Jun 03, 2019 7:56 am quote
just tested mine and 6K is the number
Mon Jun 03, 2019 8:42 am quote
Will be taking it bad apart on Thursday to see what is amiss.
Mon Jun 03, 2019 9:46 am quote
I suspect one of your sliders is wrong or they are backwards
Tue Jun 04, 2019 5:01 am quote
have you run the bike with the clutch housing off?
It can damage the springs.
Tue Jun 04, 2019 6:13 am quote
Nope.
Wed Jun 05, 2019 4:43 am quote
~I can wholeheartedly recommend the Hit clutch for the mp3 500
Mon Jun 10, 2019 2:54 am quote
Found 2 problems.
One, I think I cleaned off the variator with Carb Cleaner instead of brake clean and is leaves an oil residue. Cleaned that off. Brought up the RPM a little.
Then the big thing was the loose spark plug that the lead wasn't plugged into.
I must have loosened that plug when I put it away 4 years ago to add fogging oil to the cylinder and then must have loosened the other plug to spray penetrating oil before starting it and didn't check to make sure both plugs were tight.
Then yesterday going down the road lost all power when the plug came out. I figured out what the issue was before the scooter stopped rolling by the sound.
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1238s ][ Queries: 25 (0.0275s) ][ Debug on ]
