Steel center part of brake drum became loose
1974 200 Rally, 1970 180 Rally, 1980 P150X and P200E
Mon Jun 03, 2019 8:18 am quote
On my Vespa, some play developed between the steel center part and the aluminum casing of the brake drum. The steel part can't be welded to the aluminum, and the internet does not give any advice either. Must I throw the brake drum away, or does anyone have some advice?
GL, PK, PE200
Mon Jun 03, 2019 8:29 am quote
Pics?
1979 P150X, 1983 P200E, 1987 T5, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Mon Jun 03, 2019 9:32 am quote
Scrap it. Is it original or aftermarket??
Mon Jun 03, 2019 9:52 am quote
Original, but I think I will scrap it.
74 50s x2 78 P200 84 Cosa 58 AllState 68 Sprint 80 50special + projects
Mon Jun 03, 2019 10:05 am quote
+1 or make an ashtray.
The way these are made is by the permanent mold process which Piaggio is an expert at. Iron or steel molds are filled with molten aluminum much like die casting except generally using gravity rather than pressure - it's usually cheaper on larger parts. The brake drum/hub has the steel brake part & splined hub inserted into the mold and the aluminum solidifies around it, contracting tightly. This is the same way your brake pins are held in your motor case.
Interesting though that it should separate, let's see pics. Any cracks?
Tue Jun 04, 2019 8:46 am quote
No cracks, but you can see that someone tried to fix it before.
Tue Jun 04, 2019 12:05 pm quote
Jesus Christ, do you really want to risk your life with that? Just get on the interwebs and order a new one. How is this even up for discussion?
BTW I suggest not going the cheap route and re-using your cotter pin.
Tue Jun 04, 2019 12:41 pm quote
Yowie! It appears to be genuine Piaggio. Which Vespa and what is its history? Depending on who did what, I'd give the whole bike a careful close up look over.
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Tue Jun 04, 2019 5:20 pm quote
Looks like “bodgy” work to me.
Mon Jun 10, 2019 3:28 am
NotAutomatic has been ejected from this topic
Mon Jun 10, 2019 4:06 am quote
PICS... so we can play at home...
I dunno what that wheel is, but dang dats bodgy!
Whats the overall drum look like (im not 100% sure what model its off)?
Whats the rest of the scoot look like?
I see your location, so that may explain the "repair", or not.
1979 P200E
Mon Jun 10, 2019 7:04 am quote
That is terrifying to look at
'64 Motovespa 150S (177) , '64 V90
Mon Jun 10, 2019 8:35 am quote
The funny part is that it is even dimpled wrong.
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.4443s ][ Queries: 25 (0.0706s) ][ Debug on ]
