Open Type Handlebars
1x VNA1T
Wed Jun 05, 2019 12:56 am quote
Just starting a Sei Giorni project and am thinking about what sort of handlebar shift mechanism to use. I could go the way of original type bars but I'll be using a P2 motor and am not sure if the shifter will work with the 4spd gearbox... or go down the custom route... Has anyone done a similar conversion? Thoughts?
Wed Jun 05, 2019 2:12 am quote
why would the original handlebar shift mechanism not work?
1x VNA1T
Wed Jun 05, 2019 2:28 am quote
Not sure, that's why I'm asking. The original shifter mechanism was designed for a 3spd and the P range motor is a 4spd... maybe the shifter doesn't have enough throw for the 4spd??
74 50s x2 78 P200 84 Cosa 58 AllState 68 Sprint 80 50special + projects
Wed Jun 05, 2019 5:45 am quote
Should be enough throw but you may need to tweak a bit to get enough at both ends. I put a GL150 motor in my VB1 and had to deal w/ the same situation. A friend sent me a headset that was all set up for the gearing upgrade, so looks to have been done before.
featuring 1,*, 2, 3 and 'FAST'
bare metal cafe racer
Wed Jun 05, 2019 6:11 am quote
You need a ~45mm diameter pulley. I made a 42mm one for my VBB w/ p200 - only just have to rotate past the 4th mark. It will depend on the angle of turn the sei giorni gear select has. What’s the original setup you are working with - some pics of the headset and gear workings would help.
1x VNA1T
Wed Jun 05, 2019 10:22 am quote
Thanks Pheas. There's nothing really there at the moment in terms of handlebars so it's really just figuring out what I want to work with. Of course, it'll just be going back to the P200 gear box selector.
Wed Jun 05, 2019 12:41 pm quote
It will work.
1x VNA1T
Wed Jun 05, 2019 7:51 pm quote
Thanks Gick
Your Rally Here   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.2585s ][ Queries: 25 (0.0305s) ][ Debug on ]
