Pinasco 225 ss new
P 200 E
Thu Jun 06, 2019 12:27 am quote
Hello, I have put a Pinasco kit 225 ss on my PX 200 e with separate lubrication including 60 shaft.
i have found this :
The adjusting data, which Pinasco in its older catalogs published, are not valid any longer. The preignition should be stopped between 20 and 23° v.Ot (depending upon exhaust) and the Bedüsung the following values to be adapted: Luftkorrekturdüse: 190, mixing tube: BE3, main jet: 118-125, Nebendüse: 2,4-2,9 a hole should be bored into the air cleaner with these Bedüsung in no case, as this was to be read in old Pinascoanleitungen. This is only attached if a 160|er Luftkorrekturdüse is used! In addition, then the diameter of the drilling should not exceed 5mm. Note: Due to in series all right the high compression the Pinasco with superfuel should be operated. The compression should be taken back on use of a running exhaust system possibly be reduced, at least however preignition, and adapted the Bedüsung! "
Can someone please tell me what carburetor nozzles my si 24 with pump needed? thanks
Thu Jun 06, 2019 7:09 pm quote
I have literally no idea what most of that means, although I recognise some jet sizes. Do you have a link to the source? I've had better luck than google translate using this - https://www.deepl.com/translator
And welcome to MV!
P 200 E
Fri Jun 07, 2019 12:49 am quote
So this cylinder is not good, 213 has worked well then came the 60 crankshaft and the new original 225 head from Italy and since then it runs badly. I have tried everything, it does not want to work, . I will better use an original cylinder on long stroke.
Fri Jun 07, 2019 3:27 am quote
I have no experience of the 213 with a 60mm stroke, but I do use the Super Sport 225 kit with VRH head. I don't really know if the cylinders are different or if the stroke compensation is just in the head. However, when running with a normal (drilled) air filter, I use a pretty basic 160/BE3/130 and 55/150 in a 24/24 carb. When using a venturi, I have 160/BE2/150 and 60/160. It runs really well in both cases. I was running an original BGM BigBox but now use a Polini box.
P 200 E
Sat Jun 08, 2019 2:08 am quote
Cylinders are identical, the difference are 2 different heads
Problem is: jerking or swallowing (sprayback with siproad) when
gas take-off in the partial load range, idle 45/140 and 160/be3 128, ignition timing 18°
Sat Jun 08, 2019 3:37 am quote
Just to correct my typo, I use a 55/160 idle jet, not 55/150
P 200 E
Sun Jun 09, 2019 3:46 am quote
zip wrote:
Problem jerking or swallowing (sprayback with siproad) when
According to the instructions, a 5mm hole is drilled over the idle jet ! Is that the solution to the problem? The main jet without drilling only the idle jet? Ask for your advice
pin1.pdf
 Description:
Download
 Filename:  pin1.pdf
 Filesize:  984.33 KB
Sun Jun 09, 2019 4:32 am quote
I always drill two holes, one above each jet. The one above the main jet is bigger, probably 7mm in my case, but my memory could be bad.
P 200 E
Sun Jun 09, 2019 4:43 am quote
Main jet actually fits, the idlejet area runs too fat, I'll try and report it with the hole 5mm over the idle and take the better 55/160
P 200 E
Sun Jun 09, 2019 5:19 am quote
But not right, according to Pinasco, the mainjet meant, but this is not the problem, will not drill a hole, instead testing 48/160
P125X, P200E
Sun Jun 09, 2019 9:14 am quote
[According to the instructions, a 5mm hole is drilled over the idle jet ! Is that the solution to the problem? The main jet without drilling only the idle jet? Ask for your advice ]
Hi Zip
Couldyou post the other pages from the Pinasco manual please? I'd like to see what they say about timing, jetting, etc.[/quote]
P 200 E
Sun Jun 09, 2019 9:17 am quote
Yes
pin2.pdf
 Description:
Download
 Filename:  pin2.pdf
 Filesize:  969.11 KB
P125X, P200E
Mon Jun 10, 2019 1:01 pm quote
Perfect! Thank you ZIP
Tue Jun 11, 2019 3:00 pm quote
Zip,
Welcome...
BTW: where are you from/based?
P 200 E
Wed Jun 12, 2019 12:04 am quote
Thanks, I am from Prag Czech
Jet Eye Master
Wed Jun 12, 2019 1:19 am quote
Pilot jet is too small. Try a 55/100.
px244gs, cosa221LX, sprint177, gilera runner 180, triumph tiger 955
Location: vienna/austria (the other one, w/o kangaroos)
Sun Jun 23, 2019 1:55 am quote
hi zip
have you read this topic?
Issues with Pinasco 225 Supersport pistons
then check my utube infos, ie this one
sell this cylinder as long as it lives
its a technical design, lets say, "with a lot of potential"
the weakest of all 200cc pistons from the early 80ies
pinasco even weakens it more as the inner beams are cut through
the cylinder still only 1 port as it is just a original 198cc copy in alu
and way too wide edges at the bottom which hit exactly
the weakest parts of the very weak piston
and its more expensive than the BEST touring cyl
the malossi sport 210
sell it.
in the case of the L shaped ports, its not worth buying the GS piston
(which looks like a malossi/vertex piston)
in case of the 9T 225 with finally 3 real ports, its worth investing in a GS piston when you have the cyl already.
but... fact is.
malossi sport&MHR 210 and quattrini M232/244
are the best 200cc cylinders
why, you can read up on my fb page with a lot of more links
https://www.facebook.com/freakmoped/posts/2186029904838473?__xts__%5B0%5D=68.ARA50agJTVBr1XCr3Z-GodpFvBKZquzoW5wAaV2zsirrAjRNZWPPssunC1XrOjJ-2lUfScLAOxwVomtX69sVzsMGAsJuwUHE8PXleXSwk1DmYK3cJH9Bq5ci1gW7tR7DzUQN3_CdlqU-tuJa-xxjBO9FXLfIzY4C_l7FGkaAtDSjY3Ahen8SECDz9lzm994UE6CvtBgnrnz5dmOABjrSZmSsurqdqVhothwXdkn8Q3BeS4Y36SQx3uy4KJ4BJCtFryEleeSIC2sBpabnMcgWWyKuQsQ72NiH2YEd8vuvq908tkhHbsj0p4LO9Y9pcgsNqC2JBGiCgtVjmgWp7AKSR90SdZ6B&__tn__=K-R
P 200 E
Sun Jun 23, 2019 2:33 am quote
BEST 200cc CYLINDER RANKING by FMP:
available cylinder kits in alphabetical order:
malossi 210 sport
malossi 210 mhr
pinasco 213 super sport, 1 real port,
pinasco 215/225 9T, 3 real ports
polini 207 cast iron
polini 210 aluminum
quattrini M232
quattrini M244
But and what is best plug and play with 60 crankshaft now for mee ?
Sun Jun 23, 2019 3:55 am quote
A Malossi Sport with no case adjustments achieves around 16hp. Better than stock, but with a lot of potential.
The main thing FMP says about the Pinasco and Polini is the poor piston design. Read some more about that here - Issues with Pinasco 225 Supersport pistons
Sun Jun 23, 2019 12:18 pm quote
Yet my Pinasco Super Sport 225 has served me very well for the past five years, which includes a VERY tough tour of Spain in 2017 with a pillion and luggage, plus many other long rides at relatively high speed. Don't [blindly] buy into what FMP says about the Pinasco. I realise he is a very well respected and valuable Vespa expert, but others have had good experiences.
I changed the rings six weeks ago and the piston was in mint condition. Just saying.......there are always two ways to tell the same story.
PS. I have no reason to promote Pinasco products, other than they work well for me
Sun Jun 23, 2019 7:38 pm quote
Yes he's generally anti-Pinasco most of the time, although he doesn't admit to it. But having been on the receiving end of a broken piston that had done about 20,000km with absolutely no other issues left me a bit unimpressed. However when they do go, they go very well indeed.
P 200 E
Fri Jun 28, 2019 8:47 am quote
it fits
i have make 5mm and 7mm boost holes in the air filter, take 50/120 (2.4) and 160/BE3 122 in the carburetor, and take a bigger standard LML air filter cover, plus road sport exhaust
is the spark plug image ok ?
Fri Jun 28, 2019 9:37 am quote
It's difficult to tell from your pictures, but it looks like your plug is very white...or maybe it's just the camera flash that makes it look white? Anyhow, a 122 main would be on the lean if your engine was a stock 200 with a Sito+ (most people run a 125 main). Since your engine is a 225cc, i would guess that you might need to be somewhere around a 138 (or larger)?
P 200 E
Sat Jul 13, 2019 1:30 am quote
update:
I was bored and so I thought you build your engine back to original, built back to 57mm shaft and noticed that the cylinder has slight grooves and has less compression,
because this cylinder has already worried me enough and the spare parts are completely overpriced, i changed it against a new bgm 12 hp cylinder and made a test drive, hm drives like a PX 125, not suitable for touring, so I have reinstalled the 60mm shaft with spacer on the head, and now it runs perfectly with original exhaust.
It feels like it came from the factory. I hooope she drives now easily. I like original Zylinders
P 200 E
Tue Aug 06, 2019 4:50 am quote
To end the story I would like another supplement.
The last installed cylinder with 12 hp was not fun anymore. The original cylinder of my PX 200 was so turned out a special 10 hp cylinder was available not only in Germany but also Italy. I was in love with this characteristic. It delivered torque from the lower speed range and was very quiet to drive with sport exhaust. The new has 12 hp and the long-stroke misses the performance in the lower rpm range enormously what is particularly bad uphill, no comparison to the 10 hp with which I was so happy, well, what do you do when annoyed? Another cylinder change and hope for the best and so I thought now that the carburetor is set perfectly you try it again with the Pinasco and now works better, it is best with:
160 BE3 / main 130, idle 55/160, zzp 18°, NGK B8ES, 24/65 Primary, Road Box Exhaust, Boost Holes 5mm and 8mm, Idle mixture adjustment 1,75 turns, VRH Head A3611 Zentral Candle
Honda elite
Tue Aug 06, 2019 6:33 am quote
Thanks ZIP
Jet 200, P200E (x2), T5
Sun Aug 11, 2019 5:07 pm quote
Odd logic. Reliability isn't proven by a few good experiences, but by the lack of an inordinate amount of bad experiences. In this case there are enough separate examples of broken pistons to create a pattern that tells us there IS a reliability issue with these kits (and current Pinasco products in general, by various accounts). One counter-example does not a rule make.
Sun Aug 11, 2019 10:30 pm quote
Frank, totally disagree. Your logic is very odd, because there is an unknown number of people out there that have had similar good experiences with Pinasco components. People tend not to post about things that just work on a forum like this, but they are very quick to be negative about something that breaks, which could, as we all know be a result of the component not having been fitted, broken in or maintained correctly.
Without hearing from many more people, we'll never know will we?
Sun Aug 11, 2019 11:07 pm quote
My point was that good experiences with these kits (or any modern engineered product) should be the norm, not some lucky break that should be celebrated.
You're right, people don't necessarily go around touting how great their Pinasco kit is, because pistons not auto-destroying is expected to be the default from a reputable company (and maybe satisfied customers are just hard to come by? ).
I notice yours is an early kit with the VRH head; I know someone else who runs one of those with no issue either. The other guy I know who broke 2 pistons has the same later kit with 8 holes as I do. Maybe there's a pattern with this particular generation of SS kits?
Sun Aug 11, 2019 11:52 pm quote
I don't consider my experience to be a luck break. I just have no reason to fault the SS kit, and I've used and abused it. You may be right about the later kits. Whilst I cannot imagine the change of head has made any difference, the kits after 2015 do have a slightly different piston with two 'normal' rings. The older ones like mine have the 'L' ring at the top. Mine has always been run with pretty tall gearing (24/63) and 100/90 tyres. This keeps the revs to < 7500 in any gear. Maybe this has helped in my case.
Wed Aug 14, 2019 9:25 pm quote
malossi 210 sport
malossi 210 mhr
polini 210 aluminum
quattrini M232
quattrini M244
Why qouting the list
But not the conclusion?
Malossi sport 210 with head gasket is your first choice
Wed Aug 14, 2019 10:20 pm quote
mike mike mike
i really do wonder why you didnt get me/it by now?
even tough we had a loooot of personal chats over many years
u still did not get me and classify me still wrong
but, when i think of that you still believe that cosa lids are good
and the teninch clutch basket do not work.
No, i dont wonder when i am honest.
It would be really simple:
i am against bad hardware
I am PRO best hardware for your money
It f.. does not matter which brand it is.
again, extra for you:
it f... does not matter which brand it is.
all of the brands have products with potential
some less, some more (where u should be mors carefull!
It is not about a brand
Its about THE PRODUCTS.
i dont give a s.. about a specific brand.
Easier example:
I do like a good beer or two, three
I dont give a shit which brand
It needs be affordable, to work, to be tasty and get me drunk.
simple as that.
btw the DR 177 is as good as the quattrini M1X
and a sito original box also as good as a megadella BIG box
comeon, its very obvious that this is real.
(this is such a bad forum sftw, 25x submitting till. It gets trough)
Thu Aug 15, 2019 1:56 am quote
I never said you were wrong, only that you have your opinions on Pinasco. Nothing wrong with that. I always appreciate your advice and commentry on FB and here, but sometimes I come to different conclusions than you. Stuff like that keeps the world spinning... until of course you fall off the edge!
P 200 E
Thu Sep 05, 2019 4:17 am quote
It takes a 24 Gear so that the engine can develop its torque. I have just installed it, it is much better than before!
24/65 is already better to drive than 23/65, next comes 24/63 in or 24/62 or 25/62 let's see
P 200 E
Thu Jan 16, 2020 1:10 am quote
24/65
Now i drive Pinasco 215, standart exhaust, Main 128 and Drilled Filter with DRT 24 and its perfekt. ( Idle mixture adjustment 1,5 turns, zzp 23° )
The 215 Pinasco (57 short stroke) works better I found out.
The 225 needs a looong gear ratio (malossi or longer) But the 215 works perfekt with DRT 24
Thu Jan 16, 2020 2:10 am quote
Yes to the long gearing. I use Malossi 24/63 with 36T 4th gear, and I use 100/90 tyres which upgear it a little bit more. High speeds (for a Vespa) at < 7000 RPM is very relaxing.
P 200 E
Fri Jan 17, 2020 9:15 am quote
and freakmpoped say malossi 210 is the best
Fri Jan 17, 2020 3:18 pm quote
I love my Malossi Sport. But a friend who has been running a 210 Sport with 24/24 and SIP Road just built a Pinasco of exactly the same specs (even down to the same jetting) for his wife and thinks the Pinasco is noticeably better.
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1928s ][ Queries: 27 (0.0576s) ][ Debug on ]
