1979 p200e thinking about vespatronics
1979 P200e
Thu Jun 06, 2019 4:25 pm quote
Just picked up a 1979 p200e thinking about getting the vespatronics for a brighter headlight, hotter spark, and easier starting. I'm also going to quietly search for an electric start case reasonably. Anyone have experience with the vespatronics on an old p200e?
GL, PK, PE200
Fri Jun 07, 2019 10:34 pm quote
Welcome to the forum.
I have a variable ignition on my P200 motor that's similar to a vespatronics. I did not have any type of ignition to begin with and the motor is in a GL so I leaned toward something other then stock. Works fine once installed correctly.
The stock ignition for a p200e is OK and does what its suppose to do. What's wrong with your ignition setup now?
Good luck on that electric start p200 motor. That will take patient, time, cash, and prob shipping from over seas. Why do you want an electric start motor?.
PX150 and 1 drowned P200,
Sat Jun 08, 2019 4:30 am quote
Welome!
Yeah... hopefully you can get your engine sorted and not have to do some crazy swap or conversion.
Sat Jun 08, 2019 5:09 am quote
Re: 1979 p200e thinking about vespatronics
I've done several of these with Pinasco and Malossi. They all come with the same stator, hub, and CDI; just different bells and whistles. You will have to change out the CDI to a common 4 pole CDI (generally supplied with the ignition kit or go with BGM type) and some minor wiring. I can walk you through it all as well as have the Pinasco kits in stock.
all the best,
JG
a herd of easy shifty rats
Sat Jun 08, 2019 6:45 am quote
Brighter lights? Also consider LED's(search) and maybe one of these:
http://modernvespa.com/forum/post2325927#2325927
1979 P150X, 1983 P200E, 1987 T5, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Sat Jun 08, 2019 11:43 am quote
SIP Vape. It comes in 4 types. AC or DC, static or variable timing, 120W stator in all versions and with standalone spare parts (pickup coil, CDI, etc.)...
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.2271s ][ Queries: 23 (0.0247s) ][ Debug on ]
