FL_ 2013 GTVie Run light and TS kit right TS not working
Vespa GTV 300 IE
Sat Jun 08, 2019 11:46 am quote
Installed the above today on my 2013 GTVie.
Cannot get the RIGHT TS to work. Red light blinks but not yellow LEDS as in the left TS. These are on rear of scooter.
I have NOT installed front set as want to get rear working properly.
Jack
Vespa GTV 300 IE
Sat Jun 08, 2019 11:48 am quote
Item is M1200-GTS-BK from Scooterwest.
Called them but tech help not available and possibly someone will get back with me Tuesday.
Hoping this forum has an answer
Jack
Sat Jun 08, 2019 12:24 pm quote
Check polarity of the LEDs
Vespa GTV 300 IE
Sat Jun 08, 2019 5:49 pm quote
Not sure how to do that as Lights are pre-wired and I plugged in supplied adapter for both right and left light.
Running lights had separate yellow wire from each light and i connected each onto yellow with black stripe wire on right rear of scooter.
However I notice there are 2 yellow with black stripe wires on back right of scooter. When connecting into one, I got no running light at all. As now connected, I have running lights but TS as indicated above does not function properly on right side.
I have a video showing this but too large to upload onto this site or I do not know how. Tried attaching as a file but got error.
2016 Vespa GTS 300 i.e. ABS, 2010 Vespa GTS 300 ie Super (sold) & 2003 Honda Shadow VT750 ACE (sold) & 2006 Vespa LX150 (sold)
Sat Jun 08, 2019 8:23 pm quote
I think the problem youíre having is that you havenít yet changed the flasher unit in the legshield. Once the front installation is done the rear should work fine.
The ScooterWest video for the installation of that light set is, as usual, very clear.
The only taps to do are 1) yellow ScooterWest wire to the white wire at the turn signal flasher plug in the legshield, and 2) yellow ScooterWest wire to the yellow and black stripe wire in the wire bundle at the rear right side of the bike that supplies power to the tail light.
Vespa GTV 300 IE
Sun Jun 09, 2019 6:53 am quote
David,
Thank you. I was thinking that might be a possibility. I did the rear first thinking it would only take a few minutes. Lately a few minutes turn into hours as I re plumber the wires since I do not like taping rolls of wire and stuffing it out of the way as Robot shows in the video.
Nowhere does he suggest front being complete before the rear. Of course, that is how the video goes. On my GTV ie I have a rack on front to remove which also made it a simple decision to do the rear first.
I will do as suggested.
Thanks again
Sun Jun 09, 2019 12:08 pm quote
Can you get the horn cover off without removing the rack?
Alternatively, you should be able to fish the yellow wires using only the turn signal openings with the left kneepad thingy removed.
Use the straight part of a wire clothes hanger with some electrical tape to secure the yellow wire to the hanger.
Should be only slightly more work than the rear installation.
Vespa GTV 300 IE
Sun Jun 09, 2019 7:18 pm quote
Hello again,
Finished the install of front lights etc. Easier than the reas as I did NOT improve on the wiring ad tucking it inside the front fairing was simpler than hiding rear cables.
Bottom line is the right rear Turn Signal STILL does NOT work as it should. The yellow flashing Turn indicator LEDS never come on. Then I turn on the right TS, the front works perfectly and the rear only flashed the red led running light.
Will call Scooterwest tomorrow for resolution.
Sun Jun 09, 2019 7:37 pm quote
Yup, sounds like one for ScooterWest.
Be sure to post once it gets resolved.
Vespa GTV 300 IE
Mon Jun 10, 2019 1:17 pm quote
nal hello on this topic.
Closer inspection found that I had switched the ground wire on a connector for earlier install of additional Turn signal LEDs. That install worked fine as where ground wire was positioned didn't matter.
When I discovered and properly positioned the ground wire in the connector, all was fine and working as advertised.
Good thing if any from this is that I . got to install the rear TS assembly 2 times as I removed it and switched each part from side to side to aid in diagnosis. Result of all the switching was things worked on the left but not the right. That is when I looked very close at the wiring and found additional wires from previous install.
Mon Jun 10, 2019 1:24 pm quote
Well found.
Mon Jun 10, 2019 2:06 pm quote
jimc wrote:
Well found.
Hear hear!!!
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1385s ][ Queries: 25 (0.0349s) ][ Debug on ]
