MRP reed valve install - dremelling the crankcase
PX 200
Sun Jun 09, 2019 6:42 am quote
Hi all,
Installing the MRP vforce reed valve setup...
Was wondering what everyone does to the extra screw hole on the top of the crankcase...
Itís a little off position to dremel all the way through... is it a JB weld job?
1979 P150X, 1983 P200E, 1987 T5, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Sun Jun 09, 2019 6:59 am quote
Cut it. Check my similar build...
P221 from Rotary to Reed
PX 200
Sun Jun 09, 2019 9:51 am quote
Thanks for the thread link! Great to see your work on the crankcases! Iíve ended up using JB Weld
But cutting it should leave a huge hole on the clutch side...
Wasnít a problem?
Sun Jun 09, 2019 10:32 am quote
I didnít weld the clutch side and got no holes. If you donít overdo it, I donít think youíll have any problems...
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.8141s ][ Queries: 25 (0.1988s) ][ Debug on ]
