GTS rear brakes-where did I go wrong? UPDATE
Sun Jun 09, 2019 2:11 pm quote
Doing a bunch of maintenance at once, but needed to change out my rear tire. While it was off, took a look at my rear brake pads, and because I wasn't quite sure what the heck I was looking at (from one perspective looked due), decided that once the wheel was off it was pretty easy to pull them, and even if they didn't need changing, I'd get some experience with the process for the inevitable...
Well, removal went fine, brake pads looked great for 12K, so put everything back together. Slipped the caliper back on tightened the bolts, assembled the rear pin..... and that's when things went south. First discovered that the brake lever was squishy, then found out that the wheel was locked as well. Loosening the caliper bolts relieved pressure and the disc would spin, tightening again locked the disc.
Brake feels like there's air in the line, but don't know how. The locking is a bit more concerning. I had gently pried the pads apart before assembly, but did I need to do more?
Thanks for your input!
Sun Jun 09, 2019 2:57 pm quote
Are you sure the wheel went back on correctly, with the washers in the correct order? That's pretty much the only way the rotor will get seized on the pads.
Sun Jun 09, 2019 3:04 pm quote
The wheel is still off (taking it in to have the new tire mounted tomorrow) so it's just from attempting to turn the disc. Moved freely before I started...
Sun Jun 09, 2019 3:55 pm quote
The disc isn't seated properly until the wheel is back on and torqued up.
Sun Jun 09, 2019 4:30 pm quote
AHA! So guessing it might have not been a problem if I would have reassembled everything first. In other circumstances it's a good way to have to disassemble everything again to make something right.
Guessing the brake sponginess has something to do with that as well.....
Fingers crossed...
Mon Jun 10, 2019 3:09 am quote
Yeah...I agree with Jim. You should be fine once it's torqued.
Mon Jun 10, 2019 3:34 am quote
Do NOT bleed the brakes at the same time you replace the pads.
Mon Jun 10, 2019 4:27 am quote
Actually you should bleed the brakes, then change the pads if needed. Keeps brake fluid off the new pads.
Mon Jun 10, 2019 6:50 am quote
However, if you do, leave only the minimum amount of fluid in the reservoir until you've added the new pads and compressed them in place, otherwise there's a risk of inadvertently overflowing the reservoir.
Mon Jun 10, 2019 7:59 am quote
My reasoning here is, if the rotors have grooves worn in them, when you change the brake pads they will need to bed in. The lack of match between rotor and pad can make the brake lever squishy. So if the brake fluid was bled at the same time, one may think there is air in the line, and just keep bleeding and bleeding to get the lever to feel solid....
Thu Jun 13, 2019 6:42 pm quote
Have all of my maintenance taken care of...... wheel goes on tomorrow.
JimC, I'm still a bit sceptical, but let's hope you're right!
Stay tuned!
LX190, Primavera
Thu Jun 13, 2019 6:59 pm quote
Are you new here?
2016 BV350 White
The brakes will be squishy until you squeeze the lever severals times after you put the wheel back on. Its normal.
Fri Jun 14, 2019 6:49 pm quote
Okay...back together...
Thumbs up to jimc.... you were spot on...just as wheel nut was being snugged up, the wheel started rotating. WOOT!
And honorable mention to bean counter....squeeze or two of the brakes and they're back to normal.
Now to be sure it starts and test ride tomorrow...9 p.m. might be a bit obsessive.
Thanks all, for the sage advice and handholding....and znomit for the poke.
Sat Jun 15, 2019 1:11 am quote
Excellent fledermaus. It's posts like this that are really useful to folks. Well done for posting about it.
2016 Sprint S 150 (his), 2016 Sprint 150 Blu Gaiola (hers), 2006 GTS 250 Excalibur Gray (hers), 2006 GTS 250 Black (his), 2012 Kymco Downtown 200
Sat Jun 15, 2019 2:38 am quote
Nice going and nice reporting. See you in Lake Geneva!
Sat Jun 15, 2019 4:16 am quote
Thanks, though just me bumbling along. You should have been listed in the credits. Not much glory though. Next time I'm up to my elbows in alligators I'll have people to blame for encouraging me.
2016 Vespa GTS 300 i.e. ABS, 2010 Vespa GTS 300 ie Super (sold) & 2003 Honda Shadow VT750 ACE (sold) & 2006 Vespa LX150 (sold)
Sat Jun 15, 2019 7:43 pm quote
Very nice Dave! Threads like this are the lifeblood of MV.
GTV300 (wife's)
Sun Jun 16, 2019 2:31 pm quote
Just take it easy with the new brakes like others have said the pads have to get broken in to the rotors.
I remember years back I put new pads on an RD400 Yamaha and the first time I hit the brakes it was like they were not connected to the wheels. Nice and firm at the lever but almost no effect on forward motion!
After some riding while applying brakes with throttle on a few times the slowly started to get better and after a couple days I could even chirp the front tire while coming to a stop!
How long it will take to get to where you have full brakes all depends on how the rotors are worn.
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1490s ][ Queries: 23 (0.0331s) ][ Debug on ]
