please help to bleed front brakes
2009 MP3 400ie
Mon Jun 10, 2019 9:25 pm quote
need help to bleed front brakes after replacement of front knuckle bearings
50cc Beo, BigBeo
Tue Jun 11, 2019 12:55 am quote
The main secret is to bleed calipers not installed on the rotors. Because they should be installed with an angle which prevents air removal.
The picture below shows caliper from the inside. The yellow "thing" shows brake fluid. The hole on the upper part leads to bleeding screw.
Left part shows the caliper when it is installed. The air bubble trapped inside can't leave the caliper because bleeder is lower than the air.
Right part shows how it should be bleeded to remove air. Turn it to make bleeder vertical.
2009 MP3 400ie
Tue Jun 11, 2019 1:43 am quote
Thank you sir will try that
50cc Beo, BigBeo
Tue Jun 11, 2019 2:04 am quote
Please, not "sir", but "friend"! And always welcome.
Tue Jun 11, 2019 2:20 am quote
OR, lift the tail end of the bike up to the proper angle.
Thanks for that pic, really helps. I still don't have all the damn air out of mine.
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1836s ][ Queries: 27 (0.0295s) ][ Debug on ]
