mp3 125 voltage reg. location
MP3 Piaggio
Tue Jun 11, 2019 1:20 am quote
Hi 08 mp3 125 not charging looking at maybe the voltage reg. can someone tell me where it is on the 125 is it easy fix.
Cheers Sammy
Tue Jun 11, 2019 2:22 am quote
Right rear side cover.
Check all the fuses first.
MP3 Piaggio
Tue Jun 11, 2019 3:00 am quote
will check thanks for quick reply,
cheers Sammy
MP3 Piaggio
Tue Jun 11, 2019 5:06 am quote
Hi checked fuses look ok can,t see voltage reg, yet,---- started it up with voltage meter connected volts were all over the place from 9v, up to 11odd volts and battery dropped from 12-38 to 12-20 in matter of running 5mins, has any one any ideas.
Cheers Sammy.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Tue Jun 11, 2019 9:27 am quote
Yes... Where he said...
MP3 Piaggio
Wed Jun 12, 2019 12:21 am quote
Hi thanks for reply do you have to take side plastic off.
Cheers Sammy.
Wed Jun 12, 2019 3:22 am quote
Yes, take side cover off.
MP3 Piaggio
Wed Jun 12, 2019 4:11 am quote
Thanks for the help so far, now have regulator off but plug into it has a burnt bit on it on one of the connectors will try to post a photo for expert help
Thanks again Sammy
MP3 Piaggio
Wed Jun 12, 2019 4:30 am quote
Hi again I think I have managed to post a photo the left hand yellow terminal has been heating by the looks of it any comments. Once again thanks for all the help. Cheers Sammy.
Piaggio MP3 500
Wed Jun 12, 2019 6:36 am quote
yeah, that doesn't look good.
Now that you have the three yellow wires isolated, try some tests with your voltmeter:
With everything off, check the resistance between each pair of wires. It should be low, less than 10 ohms. Then check the resistance between each wire and ground. It should be high, > 1 meg ohm. Then start the bike and check the AC voltage between each pair of wires. It should be greater than 20 VAC when you rev the bike.
If all of those pass, then your stator is OK, and you should probably replace your regulator/rectifier.
MP3 Piaggio
Wed Jun 12, 2019 6:45 am quote
Thanks will try that in the morning.
Cheers Sammy.
Wed Jun 12, 2019 8:05 am quote
If the scooter side of that plug is bad, you can cut the wires and just use Spade lugs. Just make sure you label all the wires before you cut the connector off.
And your Regulator maybe good too. I would try by passing the connector for the bad wires and see if it charges.
MP3 Piaggio
Wed Jun 12, 2019 9:30 am quote
Thanks for the info Web-Tech.
Cheers Sammy.
MP3 Piaggio
Thu Jun 13, 2019 2:45 am quote
Hi does not look good when I tried volt meter on plug neg. top 3 yellow wires got 0.03 then on live to Earth the battery voltage 12.4 then started it up went to 11.48 and hardly moved even when revved up.
MP3 Piaggio
Fri Jun 14, 2019 4:15 am quote
Hi all --Have the feeling it must be the Stator have started to look back previous posts to find about replacing it and have got some info of Wiki, But as usual would appreciate any help before i start stripping it down, again thanks for help so far.
Cheers Sammy.
Fri Jun 14, 2019 5:56 am quote
You were measuring AC volts between the yellow stator wires, not DC I trust? And with that unplugged from the regulator the battery volts won't go up when the bike is running as it's not being charged...
Piaggio MP3 500
Fri Jun 14, 2019 7:02 am quote
Looks like you're measuring between the red and black wires, which is battery. The three yellow should be 3-phase AC volts from the stator. There should be somewhere > 20VAC between each pair of yellows when running. Nothing when stopped.
MP3 Piaggio
Fri Jun 14, 2019 10:06 am quote
Well owning a mp3 is interesting if nothing else Yes you,r right Squeazel thats where i,m testing. Received brand new voltage reg, in post and put it on started bike up and was getting 14v but would not go any higher when reved up to 5,000 revs ---on tick over the volts started to slip down to about 13-8 when i turned it of battery was charged to 12-7. also the reg, was quite hot.
Whats going on Cheers Sammy
Fri Jun 14, 2019 9:58 pm quote
that's all perfectly normal fella. all working as it should.
MP3 Piaggio
Fri Jun 14, 2019 11:02 pm quote
Hi all I would like to thank you all for you,r help and info it is a bit daunting at times with the MP3 but we got there Still not sure about how hot the voltage reg, gets but if that is normal.
Cheers Sammy.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1576s ][ Queries: 27 (0.0361s) ][ Debug on ]
