Mounting Bajaj stator plate with no degree marks.
Wed Jun 12, 2019 6:51 am quote
So I had some screwy stuff happen with my 6v stator and since I have this 12v stuff lying around I want to slap it on to see if that was my issue. The thing is the stator plate had only holes drilled no abilitie to adjust left to right. Do I make the holes larger and what position do I mount it? Also what will happen if you slight scrape one of the coils on the stator? Thanks
Wed Jun 12, 2019 8:29 am quote
Here's the damaged coils. The drill bit grazzed over and non of the wire was completely cut all the way through.
Thu Jun 13, 2019 12:55 pm quote
Nothing huh??
74 50s x3 78 P200 84 Cosa 58 AllState 68 Sprint 80 50special + projects
Thu Jun 13, 2019 1:04 pm quote
If you can get it to make spark and juice for the lites mounted on those holes, you can put a timing lite on it, figure out where it's at then drill new or elongate the old holes to get where you wanna be.
Should work, I have elongated the slots when putting a random stator on a random motor to get the timing moved enough, but have not seen just holes before.
Sat Jun 15, 2019 1:04 pm quote
How about the damage on the coil?
Sat Jun 15, 2019 1:12 pm quote
Looks like the copper survived, but you could put a thin layer of liquid electrical tape on it like chandlerman did here:
but first maybe separate the copper where those two wires are touching or close to it
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.3937s ][ Queries: 27 (0.0966s) ][ Debug on ]
