Oil code and weight 500HPE
2019 MP3 500hpe Sport
Sun Jun 23, 2019 10:33 am quote
Good day All,
After a little bit of searching, I can't find the oil code that is required for the 500HPE. If I recall correctly, it is 10W40 for the oil weight but the approved manufacture code I don't recall. JASO xxxx. Anyone help me out. Mine is new with only 3400km, and I always stick with the manufacturer oil recommendation in terms of the code, not the oil manufacturer brand per se, although I think they are recommending Castrol.
Example would be VW long life approved oil is VW 507/00 on the back of the bottle and that is what I am looking for in regards to Piaggio.
Just like to keep a liter in the MP3 for top off sake.
Thanks.
2019 MP3 500 HPE Business
Sun Jun 23, 2019 11:32 am quote
There is a novelty in the manual for the 500HPE, it is said that the MINIMUM standard is: SAE 5W40 (this leaves the possibility to 5w50 or 5W60 depending on the temperature of the place of use or the journeys made) JASO MA; MA2; SL API; ACEA A3.
The official partner is actually CASTROL.
Hoping to have been helpful
MP3 500, GTS 250 (both 2008 MY), 2010 Can Am Spyder RT-S, 2012 Honda NC700 DCT
Sun Jun 23, 2019 12:31 pm quote
Minimum viscosity standard, or minimum quality/wear standard?
Sun Jun 23, 2019 7:27 pm quote
Exactly what I was looking for.
Thank you.
I did check the manual but didn't see that. Will have to look through it again and see. Maybe I just missed it while skimming through looking for it.
Vespa Primavera 150 (2019)/Mp3 Sport 500 HPE (2019)
Mon Jul 01, 2019 7:22 am quote
Engine oil: Synthetic based lubricant for high performance
four-stroke engines. SAE 5W-40, JASO MA, MA2 - API SL - ACEA
A3
From the manual page 152 or so.
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.2545s ][ Queries: 23 (0.0338s) ][ Debug on ]
