Help
GTS300 2009
Thu Jun 13, 2019 2:02 pm quote
My GTS 300 was running fine until it stopped all of the sudden. The flashing res light from the anti theft system is now firmly ON.
GTS300 2009
Thu Jun 13, 2019 2:03 pm quote
[quote="Stanzione57"]My GTS 300 was running fine until it stopped all of the sudden. The flashing red light from the anti theft system is now firmly ON. Wonít start. Help
Thu Jun 13, 2019 6:41 pm quote
I think solid light means the immobilizer has not been disabled. So maybe the kill switch is "on" or the key is not recognized (antenna disconnected, etc).
2016 Vespa GTS 300 i.e. ABS, 2010 Vespa GTS 300 ie Super (sold) & 2003 Honda Shadow VT750 ACE (sold) & 2006 Vespa LX150 (sold)
Thu Jun 13, 2019 7:03 pm quote
Check to see if the spark plug cap hasnít come loose or fallen off. That stops the bike cold. It has happened to me with my 2010 GTS. I donít recall what the immobilizer light does when that happens though.
Thu Jun 13, 2019 10:33 pm quote
Re: Help
Check how many flashes there are before the red LED stays on. Read the immobiliser section of the workshop manual (page 84 onwards) and see which symptom you have. Report back and we might be able to suggest remedies.
https://manuals.wotmeworry.org.uk/Vespa/GTS300%20Super/
GTS300 2009
Fri Jun 14, 2019 2:14 am quote
Red light stays on although blue key is out.
GTS300 2009
Fri Jun 14, 2019 2:29 am quote
Thanks for the support. I will report back
GTS300 2009
Fri Jun 14, 2019 2:31 am quote
Berto where is the kill switch located?
Kitted Vespa 2017 GTV 300, BMW 2017 C650GT, Ural 2019 Gear Up
Fri Jun 14, 2019 2:37 am quote
Should be on the right handlebar on all bikes and scoots. Red button, flip it on and off.
GTS300 2009
Fri Jun 14, 2019 2:40 am quote
Oh that one... no itís not the problem. But thanks.👍🏻
Fri Jun 14, 2019 5:49 am quote
That is odd. It should of course just flash for a few days.
First things first - is the battery fully charged and reading at least 12.6V at rest? Are the battery terminals tight, and are all fuses reading low resistance? Just eyeballing the fuses isn't good enough...
GTS300 2009
Fri Jun 14, 2019 6:07 am quote
Battery changed couple of weeks ago, also the voltage regulator.
Will see about the fuses and what is recommended on service manual
Will get back to you all.
Thank you
GTS300 2009
Fri Jun 14, 2019 8:50 am quote
People I ended up with the mechanic, but thanks for the support. Great weekend to you all
2016 Sprint S 150 (his), 2016 Sprint 150 Blu Gaiola (hers), 2006 GTS 250 Excalibur Gray (hers), 2006 GTS 250 Black (his), 2012 Kymco Downtown 200
Fri Jun 14, 2019 9:36 am quote
Keep us posted on what the problem was and what the repair was.
Good Luck!
GTS300 2009
Fri Jun 14, 2019 10:04 am quote
Will do
GTS300 2009
Wed Jun 26, 2019 1:23 pm quote
Hello people, as requested here is the information. Vespa 300GTS is ok, me too.
Turn out the new electric regulator went crazy . Had to be replaced, computer scanner showed 4 code resetting.
All work done.
Best of all is the fact that I was able to find a true Vespa mechanic.
Best to you all
Your Rally Here   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1481s ][ Queries: 26 (0.0401s) ][ Debug on ]
