Help
T5/px150
Sat Jun 29, 2019 9:52 am quote
So scoot has been running fine no problems been slowly hitting it up started with px150 engine non autolube. Put a pinasco 177 kit on 26mm carb running sweet then today I put on a new clutch 23 tooth from beedspeed put back all fine all parts back on but now for some reason the kickstart feels jammed and flywheel wont turn cant think what it could possibly do as was fine before??!?!
73 Rally, 74 Rally, 76 ET3, 80 P200, 63 Li125, 65 Li225 Silver Special, 86 Elite 80, 2015 HD Road Glide Special, 2011 Ural Tourist
Sat Jun 29, 2019 9:56 am quote
Can a moderator move this to the Not So Modern side?
Last time i tried, a 7 spring 23 tooth P200 clutch wont mesh with a PX primary. Itíll be a bitch getting the 23 tooth out.
Once out, put your 20 or 21 tooth PX150 clutch back in. If that works fine then thereís your problem.
T5/px150
Sat Jun 29, 2019 9:58 am quote
I had a 20 tooth in there before why wont it work with it as I was told this would work fine
Sat Jun 29, 2019 10:00 am quote
Ah. If youre running the 20 tooth now, get the 21. 23 didnt work for me but 21 works just fine.
Sat Jun 29, 2019 2:14 pm quote
The 23 will not fit a 68 or 67 tooth cush drive gears and your PX prob has the 68 tooth cush/primary gear. Go with 21 to work fine or maybe a 22. The 22 will not have to pop off the line as a 21.
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1913s ][ Queries: 25 (0.0321s) ][ Debug on ]
