ABS sensor
MP3 500 LT sport abs
Tue Jul 02, 2019 9:25 am quote
Hi changing side headstock bearings and it says on page 310 to remove leg shield back plate and disconnect abs sensor , But disconnecting battery would do same thing and be easier or am I wrong
2019 MP3 500 HPE Business
Tue Jul 02, 2019 10:48 am quote
an ABS on a 400rl ........
Are you sure
Tue Jul 02, 2019 12:17 pm quote
sorry I should have changed that I now have a 500 sport LT ABS
Tue Jul 02, 2019 12:31 pm quote
It's the wire that needs to be disconnected to dismantle enough to get at the bearings properly. However, removing the back plate is a RRPITA - better to cut the wires and add a new waterproof connector pair. Same with the speed sensor wires.
Tue Jul 02, 2019 9:52 pm quote
So, change it.
Wed Jul 03, 2019 12:20 am quote
Thanks JIMC sounds good advise I know on a car if any power gets to the hydraulic modulator it can wreck it thought it was because of that
Wed Jul 03, 2019 12:26 am quote
I forgot to say that's if no brake fluid is in
Wed Jul 03, 2019 12:32 am quote
I should have added that in any case you should disconnect the battery negative if you do any work on the wiring.
Gilera Fuoco 500ie
Thu Jul 04, 2019 12:13 pm quote
be carefull the abs pump don't like to turn dry
Team Scooter Trash for Petfinder Foundation   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1120s ][ Queries: 23 (0.0334s) ][ Debug on ]
