P200 no ❤️ On reserve
1974 Rally USA 200 1980 P200e
Thu Jul 04, 2019 2:09 pm quote
So after a complete carb clean/rebuild my P died shortly after I put it on reserve? I filled the tank and put it back in the regular running position and every time I gave it throttle it died. After a bit of very slow ramping rev. I got it to return to normal.
Tank is clean.
Iím thinking itís the rubber petcock disk?
74 50s x3 78 P200 84 Cosa 58 AllState 68 Sprint 80 50special '66(?) Super125 + projects
Thu Jul 04, 2019 2:23 pm quote
Get a chunk of fuel line and a connector nipple, hook that to your fuel line where it usually connects to the banjo fitting and then do a fuel flow test into a can. You can pull your banjo and clean the filter screen inside while you're in there.
Fri Jul 05, 2019 4:20 pm quote
Do you mean clean the float bowl screen or the inside the tank filter?
Sat Jul 06, 2019 3:44 pm quote
You're right, it's the screen on top of the float bowl. I've been dealing w/ all smallframes lately and theirs is under the banjo. If you cleaned it when you rebuilt the carb it should be clean, but if there is debris already, the problem is upstream and likely that rubber disk you mentioned disintegrating. Did you check your flow?
Sat Jul 06, 2019 4:02 pm quote
I've had my rubber disc come apart and block the flow to my carb before...on the way to a rally in fact...on the side of a VERY busy highway...right as the sun went down (at least it wasn't raining). It took about 30 minutes to diagnose down the problem...many because i didn't want to unload all of my camping gear and remove both the seat and tank.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1397s ][ Queries: 25 (0.0330s) ][ Debug on ]
