Firing up an ET2 after sitting for 8 years
Vespa ET2
Thu Jul 04, 2019 2:36 pm quote
Newbie here, but very grateful to the wisdom left by many others that have gotten me as far as I have in trying to get my 2003 ET2 running again after 8 years parked in a garage.
First steps taken: new battery, new spark plug, filled gas tank. wouldnít start.
Next: Pulled carb, dropped some gas in manually and it started for a few minutes. Pulled apart carb to clean (original Weber), in process snapping lower cable. No luck finding replacement parts for Weber, went for full refit: replacing with new lower throttle cable, new Dellíorto carburetor, and new starter. All went back together like a charm (once I was able to get slack on lower throttle cable to get top end in), but still wonít start. Any ideas as to next steps please?
2008 GTS250, 2009 S150, 2017 GTS300Super, 2006 GT200
Thu Jul 04, 2019 3:49 pm quote
When you say ďwonít startĒ does that mean it wonít crank over or is it just cranking and cranking and wonít fire up?
Vespa ET2
Thu Jul 04, 2019 9:55 pm quote
Hey Rob, cranking but doesnít fire up. Battery / spark plug seem fine.
Thu Jul 04, 2019 10:22 pm quote
I just happen to be working on an ET2 right now that had been sitting since 2013. Guy dropped it off with a box full of hop up parts (70cc cylinder kit, variator and clutch spring kit, and a 19mm Dellorto. My impression is that these things want to run. Seems no matter what I do it wants to start, even if itís not running well.
If itís cranking and wonít start youíve got to start by checking the spark and the fuel. Make sure that spark plug has fully snapped in to the plug lead. Remove it and crank the bike. Make sure you see a spark. Make sure all your connections are tight on the carb at the hose coming from the air filter and at the intake manifold. Check the fuel tap. It has 2 hoses coming from it. The larger one supplies the carb with gas. If you disconnect it and gas comes pouring out the tap is bad and can cause flooding. If you suck on the smaller one, which is a vacuum line, and the fuel flows out the other one, the tap is working correctly. If you installed your new aftermarket carb and hooked up the fuel supply line and not the vacuum line that could possibly be part of the problem. Spray a spritz of starter fluid in and crank it. If it fires up, burns up the starter fluid, and then cuts out you will know thereís a problem with fuel supply.
Enough for now. Try those things and we can get back at it tomorrow
Vespa ET2
Thu Jul 04, 2019 11:02 pm quote
Thank you so much Rob! Will not be until later today but will get on the case! Iím getting a spark, which means I suspect something is up with the fuel supply (although as I didnít have starter fluid on hand I again tried manually dropping some fuel in via the manifold and no luck the second time). Iím fairly confident everything went back together ok, hoses on tight and two bolts for carb to manifold cranked down. First action will be to buy some starter fluid and see how I go from there, also checking to see draw on the vacuum line.
One detail I left out is that I shipped it (from UK back to Spain) before storage so it was left with no fuel for those eight years (the carb was really gummed up with residues).
Best of luck with your ET2 project.
Vespa ET2
Fri Jul 05, 2019 10:35 am quote
Ok, so:
Spark: check
Starter fluid: ran (if roughly)
Vacuum tube: sucked on it and got fuel through, but both ends disintegrated (will need to replace)
=> got it running, but was leaking lots of fuel so stopped.
Question: worth replacing fuel filter (or anything else?) or just fuel lines?
Thanks again!!!
Fri Jul 05, 2019 10:52 am quote
For now, just the fuel and vacuum lines. There'll be something else down the line...
Vespa ET2
Fri Jul 05, 2019 11:15 am quote
Would you know the diameters on the fuel and vacuum lines for the ET2? Iím looking for replacements online but not much luck, looks might just get generic tubes. Could be 10 and 12mm diameters? (Iím no longer near garage where Vespa is at...)
As an aside, my 11 year old son (not coincidentally about how long Vespa has been in storage?!), and who has been helping me get it running asked: ďhow do you know if you can trust the advice?Ē A: if they drive a Vespa they canít be that bad....
Sponsor
Granturismo 218
Fri Jul 05, 2019 3:34 pm quote
The fuel line should be 6mm inside diameter. I think the vacuum line is 4.5mm.
2016 LXV 150 ie, 1978 Vespa P125, 2019 Piaggio Liberty 150
Fri Jul 05, 2019 4:48 pm quote
Love it that your son is getting involved and heís is thinking, and using logic, first, get advice from trusted and reliable sources. Helping learn to fix this scooter is a very good experience for him and for both of you. Keep us posted on your progress.
Vespa ET2
Wed Jul 24, 2019 5:53 pm quote
Thank you all for your help and support, quick update. I finally got new fuel line (6mm internal diameter) installed (just the main line from deposit to carb, this one had disintegrated at both ends and leaked copious amounts of fuel once I got it started) and got my ET2 to run for first time in almost a decade. Still a few more problems: The electric starter doesnít turn the engine over to start but the kick start gets it fired up on the first go. I installed a new battery a month ago, will have to check whatís up. The steering also felt a bit wonky, need to recheck that tires are holding air pressure. Next challenge will be getting paperwork up to date to get it back to road legal!
2003 ET2 (SOLD); 2004 GT200
Thu Jul 25, 2019 7:06 am quote
Glad to hear you're up and running! I would note that the kickstart mechanism is not exactly designed for repeated use; it's capable of bailing you out in an emergency but it's not robust enough to hold up to continuous use. I highly suggest you tackle what's causing the electric starter to not work. Definitely test the battery; it doesn't take much to cause it to drop below a level that won't enable electric start.
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1411s ][ Queries: 25 (0.0414s) ][ Debug on ]
