Data Buffer Full
GTS 300SS
Sat Jul 06, 2019 7:07 am quote
Hi all...first post to the forum....running a GTS 300 SS 13 plate ...just had diagnostics due to engine management light coming on when at full throttle and speedo reads 75+ throttle off and it goes off.
Dealer cleared fault be it it still happening....Scooter was running fine up until battery change a few weeks ago after it giving up whilst out on scooter.
Any help appreciated before it goes back again for a free plug-in
Sat Jul 06, 2019 7:32 am quote
Check the alternator output at high revs - if above 14.6V then the regulator has failed, you will be damaging the battery and the engine management light will come on. Perhaps this is why your first battery failed...
GTS 300SS
Sat Jul 06, 2019 7:39 am quote
Battery was from new.... so 6 years old and scooter had been sat up for a while with no use...think battery was just old..?
Sat Jul 06, 2019 7:45 am quote
OK, so that explains why it gave up - but the CEL coming on at high revs is a clear sign the regulator has crapped out.
GTS 300SS
Sat Jul 06, 2019 8:54 am quote
Will be going back to a Dealer for a free plug-in ..see if it shows up anything new as they cleared the fault ...may be new rectifier time ..?
Sat Jul 06, 2019 8:56 am quote
It could possibly be something else - but the rev test you can do yourself, surely?
GTS 300SS
Sat Jul 06, 2019 9:02 am quote
Will get it checked 👍🏻🛵🐗
LX190, Primavera
Sat Jul 06, 2019 2:16 pm quote
Re: Data Buffer Full
Batteries donít give up while youíre out riding around. They die slow quiet deaths in the dead of night. Usually a winters night.
GTS 300SS
Sat Jul 20, 2019 4:46 am quote
Update ...took GTS back to Dealer today put back on Diagnostics and got code P0201 come up...cleared this but still issue with light coming on and full throttle so now thinking it could be an injector issue..?
Piaggio Fly 150
Sat Jul 20, 2019 5:30 am quote
Have you checked the voltage regulator? You asked the question and the most knowledgeable expert here said check the VR. So check the effiní regulator.
Sun Jul 21, 2019 7:48 am quote
Have you put a voltmeter on the battery to check voltages yet?
On a vehicle with a computer Step ONE to ANY electrical or running issue is to test the battery and the CHARGING system. Have you done that? If not, you're chasing your own tail right now.
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1971s ][ Queries: 25 (0.0465s) ][ Debug on ]
