How to adjust the air mixture scre on px200 disk?
Owned Vespa Rally 200, V90, Li150 series II...now a PX200
Fri Jul 05, 2019 8:40 pm quote
When my bike is at idle and I blip it, it bogs a little, so I'm thinking I need to adjust my air mixture screw? It runs fine otherwise.
It's the type that sticks out and you adjust it with a 7mm wrench.
The thing is I can't reach the screw because the starter motor is in the way. Any special tools to get in there?
1963 Allstate, 2005 Vespa PX150, 2001 Harley 95 ci Dyna
Sat Jul 06, 2019 11:02 am quote
I had the same problem with my 2005 PX150. I bought a pair of 11 inch pliers with the tip bent at 45 degrees. This tool works fine.
https://www.homedepot.com/p/TEKTON-11-in-Long-Reach-45-Degree-Bent-Nose-Pliers-34404/206200670
I had the same off-idle bog and turning my idle mixture screw counterclockwise just a half turn solved the problem.
PX200, Moto Guzzi V7 Cafe Classic
Sat Jul 06, 2019 1:09 pm quote
Seen pictures on here of spanners bent at an angle to get in there. Probably stuck in a vice, heated and bent over.
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Sat Jul 06, 2019 10:44 pm quote
Lots of options, been discussed lots of times.
Here's one idea, use search for others.
Sat Jul 06, 2019 11:41 pm quote
I always use the search function first. With all things vespa, things change. I thought maybe after a while someone would have come up with a proper tool.
Thanks for the help and picture though
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1624s ][ Queries: 28 (0.0491s) ][ Debug on ]
