Vespa GTS300 Instrument Cluster Connectors
GTS250
Wed Jul 10, 2019 1:29 pm quote
Greetings,
Would anyone happen to know where I could find female instrument cluster connectors(from the main harness) that connect to the Instrument Cluster? Tried searching online at various automotive connector shops but am unable to find anything remotely close.
Alternatively, if you happen to have your instrument cluster open, mind taking a few close up shots of the connectors.
Im considering retrofitting the instrument cluster on my 2007 GTS 250 with an analog one from a GTS 300. I studied the wiring diagram and they appear to be very close.
Thanks In Advance
2008 GTS 250
Wed Jul 10, 2019 1:57 pm quote
Is it not the molex mx150?
GTS250
Wed Jul 10, 2019 2:59 pm quote
Thanks for your response. Perhaps one of the connectors is an MX150, however the other 2 connectors (4 pin and 8 pin) are unlike anything I have seen before See attached photos
GTS250
Fri Jul 12, 2019 7:20 pm quote
If anyone happens to have the GTS Wiring Harness or happens to be working or replacing your instrument cluster, can you please take several photos of the instrument panel connectors on the harness. Many of the major online electronics(Arrow, Mouser, ...) stores require several photos to try to identify the connector. I've studied the wiring diagram between the 250 and 300 and believe that a 300 instrument cluster can be made to work with a 250. In parallel also going down the path of repairing my LCD. Thanks in advance!
2008 GTS 250
Fri Jul 12, 2019 8:02 pm quote
Your best bet might be to source the female socket like on the 250 cluster then solder the leads off that to the flat ribbon on the 300 cluster
GTS250
Sat Jul 13, 2019 5:13 pm quote
Found a 7 pin version of the same connector(See Attached Photos). Interesting to note that the terminals are also unique. Perhaps a proprietary connector?
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1570s ][ Queries: 25 (0.0207s) ][ Debug on ]
