Zelloni type 3 discs
2008 Vespa GTV 250 1962 VBB 1965 VBB
Thu Jul 11, 2019 10:44 pm quote
Anyone have any experience with prematurely worn Zelioni type 3 discs?
I absolutely love mine on the GTV but just noticed the rear has excessive play after only 16,000km. Thatís not value for money at $145 USD each! Front seems fine although I did free up the seized buttons (thanks YouTube), which I think is what caused the rears to wear so fast.
Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956 - Moto Guzzi Airone 250 Sport 1951
Fri Jul 12, 2019 2:06 am quote
With many holes in the disc the brake pads are consumed faster, brakes better but consumes more brake pads; consumption is different because in front of you you brake less and behind more.
The erosion of the metal in the disc is partly due to a coarser grain than the metal molecules which allows greater friction, there is nothing else to brake very much ... we need to increase friction by working on greater roughness but be careful. ... also increases the heat that in some cases can deform the discs or vitrify (harden) the brake pads.
Fri Jul 12, 2019 4:45 pm quote
I might have been a bit vague with my description. The disc surface and pad wear is fine. Itís the two discs that are held together with buttons which have the play or slop. I tried to upload a video but it wouldnít accept.
Fri Jul 12, 2019 6:32 pm quote
Does you scoot have ABS?
How will any different disc make it stop better than the grip of the tyres on the road surface will allow?
Fri Jul 12, 2019 9:32 pm quote
I think it's more for an aesthetic question ...
Fri Jul 12, 2019 9:35 pm quote
You say where the brake disk is fixed? Where are the bushings?
GTV Sei Giorni
Sat Jul 13, 2019 12:28 am quote
Try to opload the vid here: https://streamable.com/
And post the link.
LX190, Primavera
Sat Jul 13, 2019 1:36 am quote
Is there actually a problem or are they just rattling too much?
Is there a spec on the amount of float they should have?
Sat Jul 13, 2019 8:18 am quote
Iíve uploaded the video on streamable. Not sure if that worked.
The two discs that are tied together with buttons have significant play and do rattle. They brake fine, just rattle. Not sure how else to describe.
GTV Sei Giorni
Sat Jul 13, 2019 8:45 am quote
If you upload the vid, you get A url( link) . Please post this url.
Sat Jul 13, 2019 5:07 pm quote
https://streamable.com/tl675
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1492s ][ Queries: 23 (0.0264s) ][ Debug on ]
