GS150 Carbs
GS150, LI200, TX200, PX125, T5200, SX200, PX125 CUTDOWN
Wed Jul 31, 2019 1:45 pm quote
hey folks.....
anyone got any experience of PHBL carbs on GS150 engines? i just picked a gs150 up with a PHBL 20 on it. ive only ever been familiar with flat side vespa carbs so am a bit stumped on these. engine starts on choke, then overrrevs like crazy, then dies. wont start at all without choke. spark looks ok, fuel is getting in ok...im using 1 and 1/2 turns on airscrew (like a flatside) is that right?
Wed Jul 31, 2019 2:00 pm quote
pic1
Wed Jul 31, 2019 2:05 pm quote
carb shot
Thu Aug 01, 2019 6:24 am quote
was an air issue........check out the split carb rubber........hopefully a new one will fix it!
Honda elite
Thu Aug 01, 2019 6:45 am quote
Nice find on the crack keep an extra boot on hand your GS looks great did you do the carburetor modification yourself? Any other mods?
Thu Aug 01, 2019 1:23 pm quote
Would not be hard to fit an si carb
If it was mine Id fit an SSI25 as a vintage race mod
Fri Aug 02, 2019 7:44 am quote
@hibbert - nah it was already on it. good call to have a spare rubber mount tho....that's a damn fine idea! cheers!
Fri Aug 02, 2019 7:50 am quote
its got an odd choke setup too ... see piccy
im more familiar with P Series / large frame in general so taking some time to find my way around these wide frames.
Fri Aug 02, 2019 7:51 am quote
got a link ? might well be the call.....
Honda elite
Fri Aug 02, 2019 8:01 am quote
Wow that is clean. Im using a similar rubber on my P200 seems like I replace it as often as the kick stand feet.
1979 P150X, 1983 P200E, 1987 T5, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Fri Aug 02, 2019 8:08 am quote
Get a Kevlar reinforced connecting rubber and you're done. Even a car radiator hose will do. Polini or Malossi rubbers split all the time...
Fri Aug 02, 2019 4:01 pm quote
https://www.ebay.com/itm/DELL-ORTO-CARBURETOR-SSI-25-DELLORTO-SS1-VINTAGE-DUCATI-PARILLA-MV-GUZZI/362710883867?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Da802206a225c4122a5c06d9f853e1801%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D362710883867%26itm%3D362710883867%26pg%3D2481888&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A142f3f74-b581-11e9-8f19-74dbd18075c5%7Cparentrq%3A54c2fc7116c0a4e88437f5a3ffe287a4%7Ciid%3A1
they can be setup for downdraft and were used on all the Piaggio factory race bikes. this listing is over priced but they can be found for ~250. but then you have to add the float that allows it to be used in down draft mode or a remote float, that will add another 150-250. look would be spot on, but performance would same as fitting an SI24 from a p200. Seem to recall that someone made an airbox to fit on the SI24 that had the look of the 150 GS.
Fri Aug 02, 2019 4:44 pm quote
I'm sure these will last longer, but I wondered whether these would transmit more vibration to the carb than the softer ones? I haven't split one yet but carry a spare.
Fri Aug 02, 2019 5:12 pm quote
Makes perfect sense ! Thanks !
Fri Aug 02, 2019 5:15 pm quote
Thanks mate - will dig into it.
Sun Aug 04, 2019 11:33 am quote
we are now up and running, and im buzzing round town. and i can get tick over/idle. but.....runs like dogshit at half+ throttle.....can barely get over 40 mph. new carb is on the horizon, but.....in a lasy chance to save me a few quid, anyone know a good jetting setup for a phbl 20 on a 150 engine? if that fails....then its new carb time
Sun Aug 04, 2019 11:56 am quote
That would be a stand out solution.
Fan of the GS airbox design.
Any idea where you saw this?
Sun Aug 04, 2019 5:24 pm quote
Can't find it, don't think it would be that hard to fabricate here's some pictures to help with motivation:
here's a GS150 with SSI27 carb on it (easier to find than the 25mm but then you have to tune it...)
and more on that engine:
https://www.germanscooterforum.de/topic/177570-vespa-150-gs-mit-150gs-motor/
sources for repop air boxes, so you don't have to feel bad modifying one.
https://www.motoricambisoviero.it/catalogo/-Scatola-Filtro-Aria-Carburatore-Vespa-150-GS-VS2-VS3-VS4-VS5--3663
http://www.vespashop-bestmotor.com/it/carburatori/2020-cassa-filtro-aria-completa-vespa-150-gs.html
1963 GL, 1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Sun Aug 04, 2019 6:23 pm quote
Those carbs are gorgeous. Were they also used on Ducatis and Guzzis of that era?
Mon Aug 05, 2019 12:15 pm quote
[quote]we are now up and running, and im buzzing round town. and i can get tick over/idle. but.....runs like dogshit at half+ throttle.....can barely get over 40 mph. new carb is on the horizon, but.....in a lasy chance to save me a few quid, anyone know a good jetting setup for a phbl 20 on a 150 engine? if that fails....then its new carb time
Would be awesome to see some jetting work make thisbthing sing. Little extra joy in riding as it starts to sing over 40 - and then moves to screaming.
(Also: Patrick- mugh appreciate links! Like!)
Honda elite
Mon Aug 05, 2019 6:19 pm quote
Anything else done to the engine besides the carburetor modification? What is the ignition system looks like it may have a vespatronic?
Tue Aug 06, 2019 4:50 am quote
[quote="charlieman22"]
i've got on order a phbl 24 - the current one is a 20 - i'll list the jetting if it sorts it out. keep you posted
Tue Aug 06, 2019 4:58 am quote
yeah - dunno, i haven't gotten into the engine yet, it does also has a battery in the tool box....no idea what this for tho......on the large frames i always remove the battery and electric start motor anyways, they usually break after a year or so.
i'm most definitely on a new journey with these wideframes......
Tue Aug 06, 2019 9:23 am quote
the saga continues.....
turns out that the PHBL BD20 is a 'right hand' carb. ie the cylinder side is on the right looking at at it from the adjuster screw side......air side to the left.
so my brand new shiny PHBL 25 is about a much use as a chocolate tpot...grrrrrrrrr
https://beedspeed.com/products/carburettor-dellorto-25mm-phbl?variant=10570066100267
looks like i gotta battle away with the BD20 - i need a manual badly, all the material i can find on PHBL is telling me that the non spring screw is a fuel screw - and must be 2 to 3 turns out - yet when i adjust it, the engine behavior its much more like an air screw? like a normal vespa PX carb....
very confusing........anyone got any ideas?
the carb i got is here....
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/complete-carburettors-dellorto-motorcycle-carburettors-parts/phbl-20-to-26mm/r2782-phbl-20bd/
Tue Aug 06, 2019 12:20 pm quote
Maybe to identify the fuel screw, take the carb off and turn the screw and see if the valves moves.
Different carb but with similar screw check. https://www.youtube.com/watch?v=A1vRMERs4RQ
Tue Aug 06, 2019 1:27 pm quote
good shout bro - ill take a look.....
Tue Aug 06, 2019 1:39 pm quote
iggy - can I back us up a few steps?
This bike is gorgeous.
Looks like it lived in a garage - was well kept.
Upgrades look more curated than haphazard.
Made me wonder - maybe it is a well matched system - but you have another issue.
e.g. bad electronic ignition box (assuming ignition is even electronic).
Curious about back story - can you fill us in a little?
Also: can you post up a set of specs that includes ignition/exhaust/ etc.
Would be interesting.
- CM
74 50s x3 78 P200 84 Cosa 58 AllState 68 Sprint 80 50special + projects
Tue Aug 06, 2019 1:51 pm quote
+1, such a clean bike! What's the story?
While we're at it what's up w/ the T5200, is it a Spanish TX200? Reference: Vespa tx rear shock query
And PX125 cutdown, what? Let's see some pics?
Tue Aug 06, 2019 2:22 pm quote
hey bro - i got from a guy in my town who got MS, he started on the resto but got too ill to finish it.......paint was done, but on road was not.....i put it in a couple of shops in my area but they knew less than me.....so i bought myself a lifting table and start this journey.....so here i am....
its a MK1 T5 (1988) but i put a P200e in it.......ill post some pics tomorrow
i do have a TX200 too - see pics.....
see below!
see below!
Tue Aug 06, 2019 2:24 pm quote
Tue Aug 06, 2019 2:32 pm quote
- CM
yeah mate - a scooter mate of mine started on the resto - then got MS, he's currently in hospital - i bought it off his missus...so am picking it up trying to get up to speed quickly and get it running. then i'll go see him in hospital, if its not too late......so i apologies to all if i seem abit desperate.......
Tue Aug 06, 2019 2:39 pm quote
- CM
Tue Aug 06, 2019 2:52 pm quote
see below!
Tue Aug 06, 2019 2:59 pm quote
cutdown can be seen and heard here mate.
"https://www.youtube.com/watch?v=n19gfrdPJlQ"
Wed Aug 07, 2019 4:14 am quote
Success!!!!!Got her running just great on idle and main jets.
Spec: Vespa GS 1959, 150cc, PHBL 20 DB Carb, B7ES plug.
1) set carb fuel/air screw (or whatever it is) to 2 turns, throttle pics up nice and comes down nice now
2) set idling screw to a decent pace idle tick over
3) moved to a hotter plug : B7ES
4) cleaned jets, fitted kevlar tube connection to PHBL 20BD
5) tweaked up cylinder head bolts
6) noticed oil/fuel leaking from exhaust port, tweaked up exhaust nut (will probably upgrade the pipe soon anyways.....
carb and jet pics attached - big thanks to all ! kudos.....
will take her for a 10 mile run tonight - i will report back.
Cheers!
Wed Aug 07, 2019 9:42 am quote
Good deal, I like those PHBL carbies. Let's see how it does on your 10 mile run.
Meanwhile, you have too many T5's and I have none. But I have many smallframes while you have none. I think we need to arrange a swap here somehow.
Wed Aug 07, 2019 1:51 pm quote
you are most correct....i love a T5.....and a gl.....
that vespa square headlight floats my boat........
way better than a GP.....
Wed Aug 07, 2019 1:56 pm quote
oohh......now that is tempting.........i love a smally.......oooher missus!
spin out went well......pinging away....think the fork is a bit loose....ill tweak that up tomorrow too.....
Team Scooter Trash for Petfinder Foundation   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.2128s ][ Queries: 27 (0.0644s) ][ Debug on ]
