300GTS wiring pin connectors
300GTS
Fri Aug 02, 2019 9:34 am quote
Just repainted our 2010 300 GTS
I have put it all back together only to realize that I have 2 pin connctors in the top right cubby not attached to anything. It could be that they never were attached to anything as the wiring harness does have some that are not in use. However I have connected battery and we have no power. Anyone know what these attache to?
I hate to take the head set and other plastic apart again only to realize it is not necessary.
Your input is really appreciated.
1979 P150X, 1983 P200E, 1987 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Fri Aug 02, 2019 9:45 am quote
Here you go...
300GTS
Fri Aug 02, 2019 9:49 am quote
Thank you, This helps a lot.
I assume main switch is related to ignition or power for the headset.
This scooter does not have factory alarm so presumably that connector is unused.
have a good day.
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1457s ][ Queries: 27 (0.0292s) ][ Debug on ]
