P125X Oil
1978 P125X
Wed Aug 07, 2019 8:13 am quote
Hello. I stocked up on some Agip oil that my local Vespa shop told me was great but Iím all out and canít find any. It said 2T city on it.
What is the recommended oil to use? My local place has since closed and the place I went to today the guy didnít really know the older stuff and said the 2T was engine oil. Itís a 1978 P125X
Will this work? Thanks
PX125E
Wed Aug 07, 2019 9:45 am quote
Hello. That stuff is fine. (I would go as far as to say itís too good for a stock motor. By which I mean itís expensive for what you need).
1978 P125X
Wed Aug 07, 2019 10:01 am quote
Ok thanks. What should I be using? Any two-stroke injector oil? Anything I should be looking for specifically? This is what I used to have but canít find it.
PX125E
Wed Aug 07, 2019 10:21 am quote
Whatever you can lay your hands on. As long as itís two stroke oil. Mineral will be fine. The synthetic ones are really for highly tuned motors.
1963 Allstate, 2005 Vespa PX150, 2001 Harley 95 ci Dyna
Sun Aug 11, 2019 7:59 pm quote
In the late 1950s, I bought a used mid-1950s Allstate Cruisaire (see photo). Ten years later, I acquired a used 1963 Allstate. Back then, I use just plain SAE 30 oil for the 2% pre-mix according to the operator's manual. While it worked, I had real problems with the plug fouling and killing the engine. When that happened, the usual next step was to coast off to the side of the road, take off the engine cowl and remove the spark plug with the Piaggio included spark plug wrench. A small carbon deposit could be seen between the electrode and ground. The carbon particle was removed using a finger nail and off I went again. It was a real pain. Fast forward to the present time, I rebuilt the 1963 Allstate to 150 cc. I also acquired a 2005 US PX150. In both cases, I started to use the Motul 710 100% synthetic 2T oil for pre-mix in the Allstate and for the auto-lub in the PX150. Since then, I have never experienced a plug fouling as a result of a carbon deposit. The new fully-synthetic 2T oils are so much better. I feel they are worth the price. A quart at Amazon cost just $17.45 and will last for a long time. It is worth the peace of mind knowing I will not encounter an engine-killing, plug fouling, carbon deposit while riding. I also feel they provide better lubrication over a wide temperature range.
One more thing, if you use auto-lube and ride in colder weather, the fully synthetic 2T oils will maintain their viscosity for easy flow and not thicken as do the non-synthetic oils. This is a minor issue but something to think about.
Here is the Amazon address for the Motul 710 2t 100% synthetic oil. Shipping is free.
https://www.amazon.com/Motul-104034-710-Synthetic-Motor/dp/B00C739LTY/ref=sr_1_2?keywords=motul+710&qid=1565578530&s=gateway&sr=8-2
Allstate Cruisaire c1955. My old 1947 Harley knucklehead can be seen in the background. Photo was taken in 1959.
Motul 710 fully-synthetic oil.
08 GTS 250, 79 P200E, 62 Allstate
Sun Aug 11, 2019 8:05 pm quote
I use Motul 710 also! Buy it by the gallon in case any friends come by.
P Series / Li / LML / Motobi
Mon Aug 12, 2019 1:56 am quote
I buy any fully synthetic oil that matches or exceeds the jasc rating. and buy it from my local motorcycle dealer by the box which knocks the price down considerably.
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1749s ][ Queries: 27 (0.0554s) ][ Debug on ]
