Wiring in 6v regulator. Quick easy question
Fri Aug 09, 2019 8:35 am quote
I bought this simple 6v regulator but I'm not completely confident how I'm supposed to add it into the system. If I where to add the one wire with the circuit I'm trying to regulate I cannot just simply add at the junction box because then there's no separation between the connection. Do I connect one wire from stator and the other to the circuit I'm regulating? Thanks
1960 Series 2 Lambretta, 1962ish API series 2 Lambretta, 1974 Vespa Super 150, 1978 Rally 200, 1965 Allstate VNB
Fri Aug 09, 2019 10:35 am quote
I would guess the black wire is a ground. The yellow wire is likely inserted into the circuit.
You could solder on a length of wire to a circle connector and then join at the junction box. Another option would be to create a "Y" from the yellow wire and then insert anywhere in the chosen circuit.
Fri Aug 09, 2019 10:57 am quote
Someone will correct me if I'm wrong but to hook this up, connect both the input and output wires to the yellow wire and ground the black wire. I'm use to regulators that have separate wires for input and output.
Treatland sells a similar version. https://www.treatland.tv/6-volt-30w-voltage-regulator-with-black-and-yellow-p/6v-30w-regulator-with-wires.htm
Good luck!
1963 GL, 1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Fri Aug 09, 2019 11:38 am quote
Rowdys correct, pemkt too. Snip that plastic connector off and just add the yellow wire in at the junction box to whatever circuit you want regulated. Black gets grounded to the frame.
Sun Aug 11, 2019 9:06 am quote
Thanks a ton folks!
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1627s ][ Queries: 27 (0.0487s) ][ Debug on ]
