8 pole ignition switch with 4 pole harness
1956 Fenderlight, 1979 P125x, 1980 P125x, 2002 ET4
Sun Aug 11, 2019 4:19 pm quote
I accidentally unplugged a couple wires when opening the headset on my P125X and I donít know where they belong. The bike should have a 4 pole switch, but the previous owner put an 8 pole in it. Can someone help?
Sun Aug 11, 2019 7:17 pm quote
Which stator are you using? 1 yellow or 2 yellow from the stator?
Do you have pics of your current headset wiring setup as where you stand now? I'm assuming there are some extra wires added if an 8 pole is being used in a 4 pole ignition.
Could test by just plugging wires, turning the ignition, and seeing if all the lights work. Get extra fuses before you try.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1677s ][ Queries: 23 (0.0452s) ][ Debug on ]
