400 wonít start
MP3 400 "Merlin"
Mon Aug 12, 2019 3:59 am quote
So we were out riding yesterday and everything seemed fine with the bike. We stopped 3-4 times, bike restarted fine. Then on the last stop, it wouldnít start. Doesnít eve turn over. Nothing.
I turned the key off and on, and all the dash lights came on as normal. But as soon as I pressed start, all the lights went out and nothing. Not a sound. Fortunately I had the presence of mind to hit the tilt lock before trying to start it a second time, before it completely died.
Iíd just changed the oil and cleaned the air filter the day before.
Dead battery? Blown fuse?
Itís currently sitting in a parking lot 50 miles from home until my husband can get back out there to jump it. I canít do anything until Thursday when I get home from the Cleveland Clinic. (Mom having surgery)
Thanks!
Mon Aug 12, 2019 4:29 am quote
yup sounds like a battery needs to be replaced.
Mon Aug 12, 2019 7:12 am quote
Sounds like the 'hidden fuse' has blown, or there's a very poor connection on the battery. Even a pretty duff battery should re-start the bike when warmed up after a run.
Mon Aug 12, 2019 8:29 am quote
Could be the kill switch again. Just flip it on and off about 20 times. If only our lives could be fixed the same way.lol
Piaggio MP3 500
Mon Aug 12, 2019 2:57 pm quote
To me, that sounds like the classic corrosion on the battery terminals. Tighten them up and you're off. Then when you get home, clean them with a wire brush and put some dielectric grease on them and tighten them up snug.
Piaggio MP3 400ie
Fri Aug 23, 2019 7:12 pm quote
Had the same issue which end up the brakes light microswitches. Check both handle to see if brakes light is up. If not, you got the answer. No need to replace them, Disassemble, clean from corrosion and deOX them.
Fri Aug 23, 2019 11:39 pm quote
that's a good shout to be honest, very easy to forget this simple test. not just on one occasion has this brake light switchs stumped even proper experienced bike mechanics.
Sat Aug 24, 2019 7:27 am quote
"All the lights went out"
So not the kill switch or brake light switch.
It's a fundamental loss of primary power from the battery. There's a bad connection - which includes the hidden fuse!
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1339s ][ Queries: 25 (0.0311s) ][ Debug on ]
