Disaster has struck our island GTS125!
GTS 125/250
Mon Aug 12, 2019 7:50 am quote
As always I appreciate the feedback.
On the cylinder head, it looks like the thermostat is mounted on the top and starboard side. Below it is a hose that goes back towards the impeller assembly. The nipple that the hose plugs into has completely dissolved from corrosion.
What are my options, keeping in mind I am in Grand Cayman and have to ship parts in the the USA.
GTS 125/250
Mon Aug 12, 2019 3:04 pm quote
Here is a picture looking down at the tstat.
Mon Aug 12, 2019 3:47 pm quote
I am afraid I don't have an answer to your question. But I thought you might like some kind of response (and free bump). I am sure someone who has seen this before will chime in.
When was the coolant last changed?
2008 GTS250, 2009 S150, 2017 GTS300Super, 2006 GT200
Mon Aug 12, 2019 3:57 pm quote
Looking at the spray pattern of rust colored fluid that hose or something near to it has failed and is spraying. If it was mine Iíd probably add some water and then run it to try and see where the fluids coming from UNLESS there was some bad sound happening too. I donít know that bike and cannot tell what Iím seeing from the picture but I wouldnít be surprised if it was that hose.
Mon Aug 12, 2019 4:11 pm quote
It could be as simple as the crap factory clamp has failed.
Have you kept up with proper coolant change frequency?
2018 LIBERTY 150S
Mon Aug 12, 2019 4:44 pm quote
Conchy,
Might help folks stay on track with your issue - if you move the hose away just enough and photo again to show them the dissolved fitment point.
Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956 - Moto Guzzi Airone 250 Sport 1951
Mon Aug 12, 2019 8:25 pm quote
I don't understand if the problem is finding the piece or understanding why it has dissolved ... what material is the nipple, plastic or rubber?
GTS 125/250
Tue Aug 13, 2019 8:21 am quote
The nipple is steel, and i am trying to find out how to replace it. It is pressed into an aluminum cylinder.
Here are a few more photos. The hose has a smaller tube branched off of it. It looks this hose is possibly a bypass hose for when the thermostat is closed?
GTS 125/250
Tue Aug 13, 2019 8:22 am quote
Shot is where the nipple was.
GTS 125/250
Close up of where the nipple was.
2018 LIBERTY 150S
Tue Aug 13, 2019 2:11 pm quote
Good job with the photos....
Yep, just as you described in the OP. A dissolved attachment point.
Tue Aug 13, 2019 3:08 pm quote
With all that rust inside - someone used plain water instead of the proper coolant (50:50 ethylene glycol based antifreeze to de-ionised water). Even in the hottest of climates it's essential to have the right stuff inside to prevent corrosion, and to change it out periodically.
GTS 125/250
Wed Aug 14, 2019 4:13 am quote
The question is:
Can I remove the remnants and is there a replacement sleeve i can have pressed in?
If not I have to replace the cylinder head, and piston.
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.3622s ][ Queries: 27 (0.0680s) ][ Debug on ]
