New owner need help
2008 MP3 250cc
Mon Aug 12, 2019 9:58 am quote
I don’t quite understand the use of the tilt lock .when I move the bike out of my garage and into the yard twice it has fallen over . Should I have tilt lock on before rolling it out even though it hasn’t been started ? Or start it in garage and engage tilt lock before moving it ? Please Excuse my ignorance 😢
2009 MP3 400
Mon Aug 12, 2019 2:47 pm quote
The tilt lock does not engage automatically. If you want it locked you have to lock it. If it is not locked, then you need to treat it like any other two wheeler that can fall over.
With the front locked you can roll it around carefully on a smooth surface but it is still top heavy and will lose balance and topple over on rough ground.
Mon Aug 12, 2019 2:48 pm quote
You need to be very careful when moving an MP3 around while the tilt lock is engaged. Due to the close spacing of the front wheels, it isn't a really stable tripod. When one of the front wheels drops into a pot-hole, it will disrupt the scooter far enough it can fall down. I suspect this to be your problem.
When moving from paved to unpaved for instance, there may be a transition where the height from one to the other surface is ~2". This is enough to cause the scooter to topple.
If you are moving around on smooth, flat, paved surfaces, it's easy to leave the tilt lock engaged and move around with no problems. It's the potential for uneven surfaces that will get you. In this case I'd advise to basically ride the scooter where you want to go, and not depend on tilt lock to keep the scooter upright. If this means getting on, turning the scooter on, and using the motor to move, so be it.
Piaggio MP3 500
Mon Aug 12, 2019 2:52 pm quote
I treat my tilt-lock as a gimmick- To me, the MP3 is the same as a two-wheeled bike- When I stop, I put both feet on the ground, when I park it, I use the center stand and when I maneuver backwards I straddle the bike and push with my feet, just like a two-wheeled cycle. I never plan on using the tilt-lock, but in rare occasions it's handy- like when the parking spot is sloped.
Because the wheels are so close together and the high center of gravity, it's really easy to tip over when the tilt-lock is on. Just a tiny bit of speed and a small turn and you're looking at new tupperware at least, and an injury at worst.
2009 MP3 400
Tue Aug 13, 2019 2:52 am quote
Having just bought one that has been dropped a couple times, I can tell you that the plastics in the front take a beating when it falls. I spent hours rebuilding broken tabs on the wheel skirts, the knee panel and the main front cowl.
2008 MP3 250cc
Tue Aug 13, 2019 12:33 pm quote
Thanks to all who responded my error was thinking that tilt lock made it more stable when moving it around when not running VERY WRONG in my opinion the factory handbook is not real informative they should put out a MP 3 Handbook for Dummies 😂 Thanks Again .Happy Riding All !
2020 MP3 Sport 500 HPE ABS ASR
Wed Aug 14, 2019 12:38 am quote
I had a 250. The wheels were pretty close together compared to my current 500. I have always engaged the tilt lock when parking and pushing it around on flat, smooth surfaces such as parking lots, my driveway, and my garage. In these circumstances it is a great convenience.
In addition, I can engage it while waiting at a long stop light, but I always keep my feet down anyway.
It can be tricky as you have discovered. It is more than a gimmick, but a lot less than a panacea.
Gilera Fuoco
Sat Aug 17, 2019 3:20 pm quote
If I am going to use the Tilt Lock for manoeuvring, I turn on the ignition and engage the Tilt Lock before taking it off the centre stand - it makes things easier on some surfaces, but not so much on others.
I haven't yet mastered the art of engaging the Tilt Lock on the final approach to a stop, but I'm not really bothered about it. I do use it if I'm stuck in a queue though.
I don't think I would trust the Tilt Lock on it's own when parking-up though, and always use the stand.
Sun Aug 18, 2019 8:53 am quote
Unless you have a LT version now (which is not sold in North America), the 250 and 500 use all the same front end suspension parts. The wheels are the same width apart.
Not sure why they seemed closer together to you.
Sun Aug 18, 2019 1:12 pm quote
I still have the 400 and a new 2019 500. The front wheel spacing on the 500 is significantly wider than the 400. The 250 was the same as the 400.
Sun Aug 18, 2019 1:29 pm quote
Is everything the wider distance now?
Sun Aug 18, 2019 1:40 pm quote
If it comes with a footbrake, yes. EU regulations making the difference between a 'two' wheeler (wheels closer than 465mm [IIRC]) and a 'trike' (has to have equivalent lighting and brakes to a car).
Sun Aug 18, 2019 2:51 pm quote
That's right, I remember now reading about the foot brake on his scooter.
Sun Aug 18, 2019 6:35 pm quote
If the "his" you're referring to is me, yeah, the scooter has the totally unnecessary foot brake.
Ironically, due to a technicality in the law, any MP3 in California can be ridden with just a car license. However, the time I was stopped for lane splitting on a three-wheeled vehicle, the officer did ask if I had an M-class license.
Mon Aug 19, 2019 1:17 pm quote
So did you leave the foot pedle in place or remove it.
I liked the foot brake on my old Honda Elite 150.
And it was so easy to do a wheeling on that thing too. Just hold back with your feet and little, give it gas and up the front end goes and then ride it out. I got some looks taking off from light in the hood.
Mon Aug 19, 2019 7:01 pm quote
I haven't removed it because when I bought the scooter it was badged as "HPE" by mistake, so that's what I though I had gotten. After some negotiating, Piaggio US offered to exchange this one for the HPE model when it comes to the US. So I'm not making any modifications that I can't easily undo.
Meanwhile, I've gotten used to the brake pedal being there, but I haven't used it and I don't plan to.
Tue Aug 20, 2019 2:56 am quote
wise choice. ~My dealer said don't use it, just there for the law.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Tue Aug 20, 2019 6:21 am quote
You can tell who the new owners are from the battle scars from drops.
I treat mine as if its not there, but use it to park and get the bike up on the center stand. Then I disengage it.
I have a lanyard I hang on the handle bars to remind me its not on, so I don't take it off the center stand and it falls over on me.
Keith,
Marietta, GA
2007 mp3 250ie
Tue Aug 20, 2019 2:41 pm quote
I am feeling like a bit of a noob all over again. After 2 1/2 years, I have her back up and running. Some surgery sidelined me for heavy upper body anything for a bit. And as you have all noted, with or without the tilt-lock engaged, she can fall over, and I just don't have it to keep that from happening at the best of times.
I don't use the tilt lock at lights (don't want to get into a bad habit, thinking it's on, when it isn't. Plus I ride a couple of other scoots so good to maintain that practice). I use it if I park for a short period, or if backing up out of my garage - again, a nice flat surface. I am a bit more than toe-touching (want a custom or carved down seat) when walking her forward or back, so the stability of the tilt-lock is helpful. But I still try to walk it and move it like it isn't there. Slowly and carefully. Like has been said - it isn't a trike. And can and will and does fall over.
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1429s ][ Queries: 25 (0.0274s) ][ Debug on ]
