Caliper start switch fix tip
2008 MP3 400
Thu Aug 29, 2019 12:56 pm quote
Just to share a fix with my starter relay switch activated with the brake caliper.
I had this problem before so knew where to check for it.
Once the housing is off, the caliper switch needs to be unscrewed as a unit (wires attached) from the frame revealing the push button on the end.
I found it to be stuck in the pushed-in position which is the "off" one.*
A little WD 40 and it was freed to pop out to the "on" one.
Pumped it a few times so it moved freely and put everything back together, this time reverse-twisting the wiring beforehand so it would not bind when screwed in. Bike started OK; easy fix.
My point is that when a button switches like that seizes up it will be in the "off" mode, thus no start. Lubrication fixes it, allowing it to spring out when the caliper is pulled.
*opposite to push-for-on which one might assume
For what it's worth...
Thu Aug 29, 2019 6:08 pm quote
those switches unplug from the wires, just unplug them before screwing them out, saves twisting up the wires and possibly breaking them.
they are also the brake light switches.
I also recommend caring at least 1 on the scoot as a spare.
mp3 500 2016
Sat Sep 14, 2019 10:05 pm quote
Caliper start switch?which caliper?
Sun Sep 15, 2019 2:13 pm quote
it is not a CALIPER start switch he is talking about as there is no such name of part.
he is referring to the brake light/start switch that is screwed into the brake resivor housing that is activated when you squeeze the brake levers.
GTV300 (wife's)
Sun Sep 15, 2019 2:26 pm quote
Using the wrong or just confusing terminology and sure muddy up an otherwise good tip!
Your Rally Here   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1416s ][ Queries: 23 (0.0401s) ][ Debug on ]
