Et2 maintenance
et 2 50cc
Sun Sep 01, 2019 9:53 am quote
Well, it is not a real project, only a bigger maintenance.
My plan:
1. drive belt change - I don't know the mileage of this, because my speedometer cable's broken some years ago...
2. brake pads change - these are very worn, although last time I bought Malossi pads
3. brake disc change - I didn't check it with tools, but it seems too worn and there is a ridge at the rim
4. brake shoes replacement - it's time to change them
5. speedometer cable replacement - I want to know my speed
6. correct my plasti dip paint - some places the plasti dip scratched and worn, the gasoline destroyed it, the oil made black spots
et 2 50cc
Wed Sep 04, 2019 5:59 am quote
First, I changed the belt. Although, the previous belt was more than 3 years old, it seems good.
The new one
et 2 50cc
Thu Sep 05, 2019 6:16 am quote
The next was the change of the brake disc. First, it didn't seem too hard, but when I tried to remove the wheel hub, I realised, maybe I couldn't do that. The Haynes recommend to use a washer, but I didn't have the correct size. At last I tried with two c-clip and a block of wood. I didn't believe the succes, but worked! Then I changed the disc and put back the hub and the wheel. The new disc is silent and shiny. I changed the worn pads too. Now, everything is awesome.
et 2 50cc
Thu Sep 05, 2019 6:25 am quote
More pics
The hub
New
et 2 50cc
Thu Sep 05, 2019 7:04 am quote
I bought new brake shoes too. I bought my Vespa in 2014, but I haven't changed the shoes. I tought, this is the perfect time for this. But I realised, the old is almost as thick, like the new one. At last I changed it, who knows...
Old and new
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1330s ][ Queries: 25 (0.0392s) ][ Debug on ]
