Kickstart kicking back
Mon Sep 02, 2019 2:29 am quote
Went to kickstart my VBB this morning and when I kick down it returns back very strongly and quite harshly.
Any ideas? seems to stop the bike from starting too
P Series / Li / LML / Motobi
Mon Sep 02, 2019 4:44 am quote
when did you last check the internal buffer rubbers?
Mon Sep 02, 2019 4:53 am quote
not since the casing went back together with new rubbers last year
1955 Allstate 1958 lambretta 1965 Allstate 1968 sprint
Mon Sep 02, 2019 7:13 am quote
Kick back
Assuming your ignition timing is where it should be, all engines will have kick back. Those engines with good compression will have a bit more. Worn out engines “low compression “ will have very little kick back.
Mon Sep 02, 2019 7:29 am quote
Perhaps fuel seeped past your carb’s float needle overnight and your cylinder has a bunch of excess fuel in it? If so, remove the spark plug, kick it over a few times to clear out the fuel, reinstall the plug, then try starting it again.
Mon Sep 02, 2019 7:40 am quote
will give that a try this evening
2006 GT200L "Lone Star"
Mon Sep 02, 2019 8:28 am quote
It does sound like timing, but is that something that can slip on a VBB? Is the points adjustment plate loose?
I had an MG I had to re-time frequently, because the distributor clamp was badly designed and the distributor could slowly rotate out of time.
1978 P150X; 1982 P200e
Mon Sep 02, 2019 3:13 pm quote
Hi There. I have a bike with this symptom and haven’t quite figured it out yet. One posts found symptom went away by replacing stator. Worth a try. I got new stator & unfortunately problem persists.
I have now perfected the art of lifting my foot fast after I quick so I don’t get whacked
Tue Sep 03, 2019 2:09 am quote
are we talking kick-back as in forceful spring return - or backfire when the thing starts??
Wed Sep 04, 2019 11:15 am quote
Kick back as in forceful spring return!
Thu Sep 05, 2019 1:35 am quote
a dodgy stator is unlikely to have any bearing on the return of the kickstart so i personally would discount that idea.
It seems to me that you may need to examine the engine internals and ascertain if you have the return spring installed correctly or has it jumped from its original seeting location
Thu Sep 05, 2019 1:43 am quote
It has been working fine and then suddenly after a ride the other day it started doing it, it's not every time more like 1 out of 5 kicks.
1979 P150X, 1983 P200E, 1987 T5, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Thu Sep 05, 2019 1:45 am quote
Condenser going bad...
Thu Sep 05, 2019 5:26 am quote
I have thought this before tbh, bike has not been running great. Will replace next time I get a chance just as a precaution and they are cheap to buy.
Thu Sep 05, 2019 5:31 am quote
Hi, can you elaborate why the consensus seems to be around the stator plate and associated periphery? I only use the electronic ignition and can only see this to be a mechanical issue.
could someone please enlighten me??
Thu Sep 05, 2019 6:51 am quote
He has a points ignition stator. Very simple system and with specific problems over time. When the kickstart kicks back it’s usually ignition related because the spark “hits” at the wrong time. The usual culprit is the condenser, if the points are in good shape...
Fri Sep 06, 2019 5:30 am quote
Thankyou - i now feel enlightened. I can now see how this would occur.
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1485s ][ Queries: 25 (0.0271s) ][ Debug on ]
