Vespa t5 classic rebuild
vespa t5
Tue Sep 03, 2019 4:35 am quote
Hello all, My first post on Modern Vespa although been registered quite a while thought I would post pic of my t5 classic which has had an extensive rebuild will post more pics and details soon. Thanks for looking.
59" Allstate
Tue Sep 03, 2019 4:47 am quote
Very Nice, Welcome aboard.
vespa t5
Tue Sep 03, 2019 9:36 am quote
Some more pics of my rebuild showing scooter as bought on lift ready for strip down before being sandblasted and etch primed to stop the metal rusting in its bare state while repairs are underway, then various pics of repairs to corrosion mainly lower front panel and very weak engine mountings - all corrosion cut out and new metal mig welded in. Then re etched and a further 3 coats of primer flatted off before 4 coats of nice gloss black more flatting then 4 coats of clear lacquer to give a nice depth of finish. Finally stonechip to underneath!!.
vespa t5
Tue Sep 03, 2019 10:54 am quote
Re: Vespa t5 classic rebuild
Strip down begins]
All rust cut out new inner plate about to be plug welded in position then new outer skin fully seam welded over the top.
Welding repairs completed and etch and high build primer applied.
First coat of gloss black to underside.
So 4 coats of primer 4 coats of gloss black followed by clear lacquer job done let the rebuild begin!!
As this is a rebuild and not a restoration its getting built to how I've imagined my ideal vespa to be built so on with a nice carbon fibre mudguard taking great care to put the mounting hole in the right place the old measure twice drill once being put i
Can not fault the quality of SIP brake caliper - superb.
Word of warning if replacing the the pivot pin I recommend you buy genuine piaggio pin and bearing cups as I originally fitted a pattern part kit on rebuilding I found it still had play!!! Fitted a genuine pin hey presto no play.
After many hours the end result my ideal t5 yep I do like my stickers lol and she's definitely a performer with mallosi kit, SIP big box exhaust, jetting and airbox modifications.
Honda elite
Tue Sep 03, 2019 2:00 pm quote
Great looking stickers and scoot!
vespa t5
Tue Sep 03, 2019 3:25 pm quote
A thank you.
Thanks for your kind comments on my t5 it's my first scooter I've always liked them but up until now only ridden motorbikes. I bought the t5 as a retirement project the only work I didn't complete myself was the sandblasting ( to messy to do at home! ) the t5 shares the garage with my modified Honda cb500 and my latest project a yamaha sr 250 it's just undergoing a dry build then will be stripped for frame painting, the tuning parts ie exhaust system , carburettor intake, filters etc are from jadus in Sweden and give a 20% increase in power - dyno proven so should be a fun machine when completed Thanks again.
Rallies Europe 2016   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1565s ][ Queries: 25 (0.0314s) ][ Debug on ]
