Balance Factor/Crankshaft Balancing
1980 P125X, 1980 P200E , 2005 Stella 177
Wed Sep 04, 2019 6:33 pm quote
Just stumbled upon these videos on youtube. Found the topic interesting and figured someone might consider this useful here.
https://www.youtube.com/watch?v=0hoE_MuFpPI
I'm assuming if your balance factor is off, you either drill out some weight from the crankshaft, or add some as he does in this video:
https://www.youtube.com/watch?v=iD6CUe5PlHo
Wed Sep 04, 2019 6:43 pm quote
and as always, FMP with a solid video on this topic.
https://www.youtube.com/watch?v=rpq_VmmPHfg
Wed Sep 04, 2019 11:10 pm quote
When I had my stock T5 crank rebuilt (machined, flowed, polished, weld added, and the pin welded), I had to bring in my clutch and flywheel because my tuner wanted to weigh them in order to get the balance factor correct all of the aftermarket parts I was using. I think he aimed for around 6500 to 7000 RPMs for when the crank would produce the least amount of vibration? Maybe it was at a higher RPM? Nevertheless, when I got to the real high RPMs (9k+), that motor with that crank was just about vibration free. Since a Smallframe (and Lambrettas) doesn't have a heavy clutch hanging off the crank, the balance factor would be different from a P range.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1368s ][ Queries: 23 (0.0343s) ][ Debug on ]
