Changed the SP on the GTS...it's no Stella.
300 GTS, Stella 4T
Sat Sep 07, 2019 7:10 am quote
What a pain in the ass.
2 ups to give...
Robot, for the tip to use a long needle-nose to pop the cap off.
Haynes manual, for saying to remove the battery cover so as to get to the clip that holds the wire.
Still a pain in the ass. At least it's only every 6000 or so miles.
GTS 300ie Touring
Sat Sep 07, 2019 7:53 am quote
Re: Changed the SP on the GTS...it's no Stella.
2 ups to give...
Well done for doing it!, I hope you got a sense of achievement when you finished the job.
Sat Sep 07, 2019 8:04 am quote
Well done, yeah it is a PITA. Next time, install a iridium plug and you won't have to change it anymore. Don't forget to put a wee bit of copper anti- seize on the threads.
Mon Sep 09, 2019 3:25 am quote
Todays logic for spark plugs is, if it is running well don't change them.
Bet I have 30,000 or 40,000 miles on the plugs in my MP3 500.
Location: Starfleet Command Engineering, Southern UK HQ,
Mon Sep 09, 2019 3:48 am quote
Not quite sure why everyone thinks changing a spark plug on the GTS bikes is such a pain. It's easy. Ok, when you do it for the first time it may seem a slow job. Second time around it's so easy peasy. Having the right tools is essential, and that's not a conventional spark plug wrench. If you really want to know what a pain in the spark plug changing butt is, then look at some motorcycles where you have to spend an hour removing luggage, racks, seat, petrol tank, then some. It can take two hours to just replace two spark plugs on some Suzukis, Yamahas, etc..lol. Sad but true!
But well done to the OP.
300 GTS, Stella 4T
Mon Sep 09, 2019 5:28 am quote
I had a tad over 7500 on the original one. The electrode was quite worn. I can def feel a difference with the new one.
Last edited by Big Daddy SnakeOiler on Mon Sep 09, 2019 5:30 am; edited 1 time in total
300 GTS, Stella 4T
Mon Sep 09, 2019 5:29 am quote
I was basically comparing it to the Stella.
2007 GT200, 2008 Yamaha C3
Mon Sep 09, 2019 4:06 pm quote
Change it when you adjust the valves. Pleace your center stand on a couple scraps 2x12s and unbolt the top of the rear shocks. When the head swings up, the plug is easier to get to.
'15 Blue GTS300 Super, '18 White GTS300 Super
Mon Sep 09, 2019 5:50 pm quote
Just putting the scooter on the side stand so some weight is on the back wheel gives you a little more space to get your hand in there.
Tue Sep 10, 2019 4:32 am quote
Replace it with an Iridium plug next time and see if that makes a difference.
GTS250
Tue Sep 10, 2019 5:29 am quote
Not - that - hard
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1897s ][ Queries: 25 (0.0334s) ][ Debug on ]
