Buying parts - Australia
Px125
Sun Sep 08, 2019 4:03 am quote
Hi all (aimed at ozzies),
Who knows the best websites to buy parts, oil, spares etc for the Australian market?
I have moved to Sydney recently and just picked up a PX150 and need to get kitted out with the usual.
Any suggestions would be great!
PX 150
Sun Sep 08, 2019 1:53 pm quote
Gps imports
PX200, Moto Guzzi V7 Cafe Classic
Sun Sep 08, 2019 2:03 pm quote
GPS stock a limited range of stuff and are expensive. I usually order from Europe from SIP or Beedspeed.
Sun Sep 08, 2019 2:17 pm quote
That is true to a point Bob... it's probably fairer to say they have a broad range of stuff that is often not in stock! That and the world's worst website! Helps if you have the Piaggio part numbers... which I get from the SIP "OEM Numbers (for the purpose of comparison)" below the description. Also I have found stuff that is actually cheaper there from time to time. It's a bit unfair because you pay GST on his parts and not on SIP's (unless it's over $1000).
But the best bit about GPS Imports is the very fast delivery (usually next day for me in Vic). And you can send them a message and they'll help you out.
Having said that, most of my parts come from SIP or Scooter-Center.
Px125
Tue Sep 10, 2019 1:49 am quote
Thanks guys. Just need to get oil for now. Do you reckon these will be ok for a PX150?
Tue Sep 10, 2019 1:56 pm quote
I don't know about those oils but I just grab whatever 2T scooter oil from Supercheap Auto and get this gear oil from there too.
Tue Sep 10, 2019 2:41 pm quote
Yep I usually buy the same one as Bob... but the 10w50 you have there is wrong. You want a 2 stroke oil, that's 4 stroke. Generally I have bought Penrite semi-synthetic (now around $21 ish a litre) but recently I've found a full synthetic for only a teensy bit more! It's here - $89.95 including free (and quick) delivery.
https://gearfactormx.com.au/product/castrol-power-1-tts-2-stroke-4litre/
2001 LML 150
Tue Sep 10, 2019 3:24 pm quote
Or an even cheaper and higher quality 2t oil is Anglomoil semisynthetic 2t - $38 for 5 litres.
2001 LML 150
Tue Sep 10, 2019 6:50 pm quote
Never seen that one around. Where do you buy it?
2001 LML 150
Tue Sep 10, 2019 7:33 pm quote
I normally get it from Thomastown.
They donít advertise or supply the big chains.. just supply from their depots. Thatís why itís cheaper. And they make it in house - better 😁
Theyíve been around since the 70ís and still going strong..
Tue Sep 10, 2019 10:24 pm quote
You could become an intermediary... I think you could go Diamond within a month!
Px125
Wed Sep 11, 2019 12:46 am quote
Thanks guys, just got a bunch of stuff from Super Cheap Auto.
Last question - Can anyone send me a link to where I can buy a gearbox nut washer/gasket? See below pic
Thanks!
P Series / Li / LML / Motobi
Wed Sep 11, 2019 1:02 am quote
I generally get mine from ebay and order a few at a time. copper washers make a good alternative to fibre if you cant get one. recently i have been playing with nitirle rubber and a flat wazher. seems to be going ok so far
as for oil, you can use SAE30 or SAE *w30. as long as its mineral based and not synthetic - synthetic & your clutch wont thank you -
10w30 and SAE30 are effectively the same at operating temperature, SAE30 is good from about 40f upwards and will be "thicker" in winter temperatures. whereas 10w30 5w30 etc are designed for "easier cold starts" the W in oil rating denotes Winter.
HTH
Thanks!
Px125
Wed Sep 11, 2019 2:59 am quote
Thanks, so synthetic oil is no good for the gearbox? Only good for engine oil?
Wed Sep 11, 2019 6:28 am quote
synthetic is no good for the (standard) cork plates you find on vespas.
synthetic as in 2 stroke oil is definitely recommended..
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.3367s ][ Queries: 27 (0.0634s) ][ Debug on ]
