Vespa oil light on then dies
2014 Vespa Lx 150
Mon Sep 09, 2019 9:48 am quote
Well I'll jump right in....I have a 2014 Vespa lx150 w/7500miles. 3weeks ago I was riding, can to a stop at a red light, the oil light came on & the bike instantly died. I checked the oil & it was very low. Put oil in it, started up seemed to run fine enough to get home. Changed the oil & filter before my next ride. I drove it round 6 times it seemed to be running good. Yesterday I drove it, same thing happened, except this time the oil level is good!? What it does now....it runs fine if I don't completely let off of the throttle....if I let off the gas it'll idle for 30secs-5mins then the oil light comes on & it dies. Any thoughts?
Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956 - Moto Guzzi Airone 250 Sport 1951
Mon Sep 09, 2019 10:55 am quote
Do you have oil leaks at the ground?
If there are no losses, my hypothesis is that it could (it is only a hypothesis) have damaged the drive shaft bearing bush ...
If the engine is liquid-cooled the head gasket could be broken with oil spillage in the cooling circuit ... worst case scenario.
Mon Sep 09, 2019 1:22 pm quote
Could just need the throttle body cleaned. That is a symptom.
2018 LIBERTY 150S
Mon Sep 09, 2019 3:07 pm quote
Agreed. Something preventing good idle.
Idle drops off, oil light pops on, scooter dies. Give it throttle is OK, let off throttle, idle drops, light on, engine dies.
I don't think it's oil related - needs to regain a healthy idle.
GTS 250i.e.
Tue Sep 10, 2019 12:06 am quote
Battery crapping out? Try charging the battery up.
Tue Sep 10, 2019 2:12 am quote
If the battery can start it, it should have enough power to let it idle for at least a little while. Cleaning the throttle body would be step one, than start with the battery if that doesn't help.
2007 LX 150 (memories)
Tue Sep 10, 2019 4:40 am quote
I don't believe the oil pressure light coming on causes it to die. The oil pressure light comes on when the pressure gets too low, as when the engine is idling down too far and quitting. It happens quickly so it is hard to observe the exact sequence.
GTS 250ie Super, Italjet Velocifero, Scarabeo 150, S50,ET4
Tue Sep 10, 2019 5:47 am quote
Idle problems are also a symptom of valves needing adjustment. At 7500 miles it might be time to check them.
Tue Sep 10, 2019 6:41 am quote
First valve adjustment should not be recommended till 12 or even 18 thousand miles. Looking for the info on that.
Wow, every 4,000 miles. Do throttle body server and adjust your valves.
Primavera 150
Tue Sep 10, 2019 7:36 am quote
Air-cooled Piaggios (Vespa and Moto Guzzi) get their first valve adjustment at 600 miles (1000 km).
2014 Vespa Lx 150
Thu Sep 12, 2019 6:39 pm quote
Thanks everyone for the feed back. Little background on me, I'm a straight up YouTube mechanic(in other words I know nothing of small engine repair w/o YouTube) lol I'm also bout 3hrs from the closest Vespa repair shop, so that's unfortunate. Anyway I'm hoping this is a bad fuel situation, as I'm in no shape to be adjusting valves or doing head jobs😅 thanks again & keep em coming👍
Fri Sep 13, 2019 12:34 am quote
I think it is sufficient to control the distance between cams and valves with a simple feeler gauge, if necessary then adjust.
On other scooter engines that I saw disassembled by my mechanic (we often discuss his work) I saw perfect engines with more than 20,000 km without the need to have ever adjusted the valves; then remove only the top cover and check.
2014 Vespa Lx 150
Mon Sep 16, 2019 11:31 am quote
Update....I put some seafoam in the gas. I just road the scoot around for bout 25miles or so. Anyway it's been idling in the driveway now for 15mins & no probs so far(crossing my fingers) bad gas I hope.....as soon as I post this it'll probably die lol
2014 Vespa Lx 150
Mon Sep 16, 2019 1:45 pm quote
Let it idle for bout an hour, walked over to check on it & noticed the check engine light was on(still seemingly idling fine). Anyway shut it off started it back up, idle for 30mins & the engine light didn't come back on so idk?
Mon Sep 16, 2019 1:48 pm quote
Why are you letting it idle so long??
Hell, I'll shut mine off at long lights now.
2014 Vespa Lx 150
Mon Sep 16, 2019 5:40 pm quote
What are you trying to say web tech? Long lights now? Huh
2014 Vespa Lx 150
Mon Sep 16, 2019 5:44 pm quote
The problem initially was that it died at idle. I was trying to see if I could get that same reaction but was unable too. So I guess that's a good thing? Hence me letting it set & idle, see if it would die again
2014 Vespa Lx 150
Mon Sep 16, 2019 5:47 pm quote
Nevermind web tech I see what ur saying😅
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1412s ][ Queries: 23 (0.0295s) ][ Debug on ]
