Smallframe overhaul TOOL's ?
2 Vespa 90 V9A1T US Model's
Tue Sep 10, 2019 5:54 am quote
Hello Chaps.
Planning on overhauling several smallframes engines and all
Can you recommend the tools that I need and those that can be done without
Looks like you can spend a fortune on factory style tools. I imagine some have come up with a method that doesn't require the tool
Some of the tools from Scooter Mercato here in the US:
-Crankshaft Installer and Extractor?
-Punch for dismantling wrist pin?
-Clutch Compressor
-Clutch Puller
-Punch for Flyside Bearing and Seal
-Best bearing extractor?
-Punch for Clutchside Bearing and Seal
-Case Separator tool
-Puch for Driveshaft
-Rear Axle Bearing Punch, Removal
-Wedge for Crankshaft
-Cush Gear Repair Tool
-Tool for Mounting Gear Selector
- Wrist Pin Puller Tool
Tue Sep 10, 2019 6:30 am quote
Re: Smallframe overhaul TOOL's ?
smallframenyc wrote:
Hello Chaps.
-Clutch Compressor
-Clutch Puller
Two very small hands. Then again, if the engines are out of the frames completely, it might go ok for you.
I love riding mine, but it's my least favorite to work on.
Tue Sep 10, 2019 6:33 am quote
I didn't find I needed it, gentle whacks with a rubber mallet were enough
not sure what this is but have built my engine without
-Clutch Compressor
yes you need it but can make one from home depot hardware if you are just doing a stock clutch and don't need to build it in the bike
-Clutch Puller
yes you need it
use a socket for a drift
heat and a gentle whack of the case against wood for the small driveshaft bearing (sometimes an oven is useful, I used my barbecue!). otherwise use sockets or drifts to drift it out
drifts / sockets
no
I assume this means punch. If you install the backing plate, you won't push the bearing out as you seat the axle in the bearing on the hub side.
drifts / sockets
no
not sure what it is, but I didn't rebuild my cush on the smallie. on the P it didn't require any special tools
if this is the 2 blocks for the spring/ball installation, definitely yes
yes
*** I forgot about the split bearing on the flywheel side. You'll want the drift to mount the race on the crank. I'm not sure which of the above is describing it. You can get the old one off with heat and a quick pry or you can use a dremel with cutting wheel to work most of the way through and then pry it apart.
Tue Sep 10, 2019 6:42 am quote
I forgot I had made this thread, might be useful to you:
Smallframe engine build - 1974 Primavera
Tue Sep 10, 2019 6:45 am quote
-Clutch Compressor
-Clutch Puller
yes you need it
drifts / sockets
no
drifts / sockets
no
yes
Thanks for the detailed reply! Really helps out!
Tue Sep 10, 2019 6:47 am quote
no sweat, check the thread I linked, it remembers more than I do at this point
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1495s ][ Queries: 25 (0.0318s) ][ Debug on ]
