GTS Rear Turn signal
2007 GTS250
Tue Sep 10, 2019 7:27 am quote
The left turn indicator on my 2007 GTS was acting weird. First thought was the switch. Then, my suspicion went to a blown bulb at the left rear signal. Upon further examination, I noticed the wiring coming across from the right signal was being shredded. Not sure what was holding it away from the tire to begin with. Taped it all up and used a zip tie to keep it from aything that would shred it, again.
Is this piece of harness something I can purchase? I've seen others on the forum have had the same issue. Here's some photos of theirs
Tue Sep 10, 2019 7:48 am quote
In most cases no, just cut out the bad section and solder new wires in. Not that hard, just practice first if you have no experience do so.
Watch some videos on how to connect together the wires before soldering.
You just kind of spread all the stands out on both wires, push the to wires together and squeeze them on together.
https://www.youtube.com/watch?v=qxqZJH3SfN4
2007 GTS250
Tue Sep 10, 2019 11:11 am quote
Thanks. Right now I've trimmed and re-connected wire with electrical tape. I'll get some proper wire and re-do it. I'd like to get the actual section of harness, though.
Tue Sep 10, 2019 11:18 am quote
I think most of the harness is one piece, so you would have to get it from a wrecked scooter. Put a post in the For Sale section. Maybe someone with a wrecked scooter will reply.
Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956 - Moto Guzzi Airone 250 Sport 1951
Tue Sep 10, 2019 11:20 am quote
Instead of the electrical tape, it would be better to use thermo-shrinking sheath as in the video.
LX 50
Tue Sep 10, 2019 3:56 pm quote
Do I see where someone spliced the wire before?
Looks like a common problem.
Sponsor
Granturismo 218
Tue Sep 10, 2019 7:32 pm quote
I've got a couple of old vespa harnesses lying around the shop that I've had to dig out of the trash every time someone tries to clean up my work area. Give me a call and I'll see what I can come up with.
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1612s ][ Queries: 27 (0.0266s) ][ Debug on ]
