Newbie main jet removal question?
Owned Vespa Rally 200, V90, Li150 series II...now a PX200
Tue Sep 10, 2019 7:03 pm quote
Trying to change my main jet, but it seems to be stuck in the stack pretty good. Any tips and getting it out. I've probably already screwed it up using pliers to get it out.
Honda elite
Tue Sep 10, 2019 7:31 pm quote
use a nail or wire in the hole and pull
Tue Sep 10, 2019 7:43 pm quote
Will that not ruin the bore size?
Edit:Tried it. Still stuck.
2001 LML 150
Tue Sep 10, 2019 8:03 pm quote
Iíve used a piece of fishing line in a big loop and pulled with a screwdriver handle.
Any strong and relatively soft thread or line should work..
Tue Sep 10, 2019 8:18 pm quote
Too late. The main jet that's on there looks ruined and it's still stuck. Looks like I'm just going to have to order a new mixer tube. a 5 min job just turned into a whole week of waiting.
Tue Sep 10, 2019 9:17 pm quote
Wrap a rag around the jet tip and pull with some pliars.
Got a pic of how bad it looks?
Tue Sep 10, 2019 9:53 pm quote
Manged to get it out. Heated it up and used pliers. After that it wasn't to bad taking it off and on. The new jet felt like a tighter fit though It's gonna suck when I have to change it again.
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Wed Sep 11, 2019 5:25 pm quote
I keep a small nail in my road kit that I put through the side holes as a puller just to help remove stubborn ones.
1980 P125X, 1980 P200E , 2005 Stella 177
Wed Sep 11, 2019 6:10 pm quote
I fold a shop rag in half, then wrap that double layered rag around the main jet and use small needle nose pliers to grip onto the main jet (making sure the pliers are gripping on the side walls, not touching the holes in any way and lightly pull it out with as little force as required.
This protects the jet from getting scratched and protects the side holes from being warped by the pliers.
Also have had some new jets come that were too loose or too tight when put into the atomizer, so I use same needle nose pliers, when mj is too tight or wont fit into atomizer at all to slightly bend the two tabs that insert into the atomizer closer together until its snug fit, but not too loose that it would fall out. When it is too loose, I use a flathead to pry the tabs apart slightly, until it fits snugly.
PX 150
Thu Sep 12, 2019 1:09 am quote
Use small channel lock pliers to hold the mixer tube after taking a strip of cloth tape to line the jaws. The one I use is 6.5 inches, which is the perfect size for the job. Hold the mixer tube softly with the pliers at the narrow section of the tube, which allows the tube to butt up against the jaws of the pliers when you are pulling on the jet. I then use a narrow pick tool through the jet and it twists right off. The mixer tube doesn't have any marks on it at all. This makes removing the tightest main jet a 10 second job.
Thu Sep 12, 2019 5:21 am quote
Thank you guys for all the tips.
Is it supposed to pull straight out, or are you supposed to wiggle it out?
Bodgerific 150 Super, 50s in progress
Thu Sep 12, 2019 5:30 am quote
Twist, wiggle and pull.
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1562s ][ Queries: 25 (0.0327s) ][ Debug on ]
