has anyone replaced the 12" rear tire with a bigger opt
2007 Piaggio MP3 250
Fri Oct 04, 2019 7:48 pm quote
New to the MP3 scene, but from my understanding they started with 12" rear wheels and then were upgraded (to 14"?) for improved stability. Is that correct?
Two questions:
1) Did anything else change, maybe on the front end to account for the taller rear?
2) Has anyone switched from the 12" rear tire to a 14" tire? If so, what was involved?
Thanks!
Sun Oct 06, 2019 3:47 am quote
Not sure where you would get wheels for 14" tires that would fit.
You can you the 13" wheels off the Piaggio YouBan.
Sun Oct 06, 2019 9:23 am quote
the 12 and 14" wheels that come on the 250 could be interchangable. they are not a bolt on wheel like web thinks. they are spline drive direct from output shaft.
I would look to see if rear disc size used is same between the 12" and 14" models. if its same diameter then its a good bet all you need is a wheel and tire to swap. but its just a logical guess.
another option might be to use the spline drive hub and bolt on wheel setup from a vespa gts. then you would have 12 and 13 wheel choices. the wheels on the back of mp3 are heavy duty. so that can be a concern for this path.
Sun Oct 06, 2019 10:13 am quote
Actually I thought he was talking about the fronts, missed the REAR, in the subject.
The whole rear swing arm changed when they updated it to a 14" rear wheel. Caliper is on the wrong side connecting the parking brake is different.
Not a lot you can do, lots of parts changed from 12 to 14 inch rear wheel.
This was hashed out by lots of people when the MP3 250 came out.
Some people just switched to a car tire. I don't advice this though.
If you want to look into a car tire I know stickyfrog is one that did so and liked it.
Tue Oct 08, 2019 7:49 am quote
I was thinking about the Yourban rear tire, I saw that there's a kit on ScooterWest https://www.scooterwest.com/13-yourban-wheel-with-hub-cap-and-mounting-hardware-each.html
A little pricey but I'm due for a new rear tire soon anyway so now's the time to look into it. I've only had my MP3 for about 10 kilometers (less than 10 miles), so I'm open to feedback from experienced MP3 250 riders.
Thanks all.
Gilera Fuoco 500ie
Tue Oct 08, 2019 1:19 pm quote
when fitting the a yourban rear rim you need to change the exhaust bracket also on some 250's depending on build date build in 2009 could do with out but if your in the Us als 250's where build in 2007 and 08
and your link is a front wheel won't fit on the rear
MP3 250 & T Max
Tue Oct 08, 2019 7:05 pm quote
I fitted a 14" rear wheel to my 2007 250. There was a posting from an Australian contributor on his experiences and I followed them.
The 14" was from the late model MP3 and came from Easyparts in Holland.
It was a straight forward job necessitating spacing out the wheel 8mm on all mounting points, this to correctly align the brake disc. I may have replaced the cap screws with longer ones too.
Comfort is improved, the gearing is 'higher'-an extra 4" rolling distance over the 12". And I'd say the handling on our twisty roads has improved-a bit more cornering clearance!
I wouldn't go back to a 12"
Thu Oct 10, 2019 3:23 pm quote
Doh! I'm in Canada on a 2007 MP3 250. I'm guessing I would need to change the exhaust bracket?
I tried searching for this but couldn't find it on the forum. Do you know if this thread is still live somewhere?
MP3 250 & T Max
Thu Oct 10, 2019 6:29 pm quote
I had previously fitted a Leo Vince exhaust and can't recall having to change the bracket. The LV system saves a heap of weight...makes a nice sound too.
2013 MP3 300ie
Thu Oct 10, 2019 10:02 pm quote
On my 50cc scoot I always used a 140/70 instead of a 130/70 rear tire - which doesn't sound like a huge upgrade, but improved stability and tire life noticably.
Oh, and apart from being a very easy upgrade, it also looked better
This is probably what you were looking for, by the way:
http://modernvespa.com/forum/topic112088
MP3 250 & T Max
Thu Oct 10, 2019 10:39 pm quote
Well done that man
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1421s ][ Queries: 25 (0.0450s) ][ Debug on ]
