FLY 150
FLY 150
New to forum
Trying to figure out why my2010 fly 150, which starts fine, idles fine but as im going down the road will decide to cut out. In the beginning it would restart after a few minutes, the last time it didn't want to restart, so I tore it apart, checking air filter, and put it back together and it started so I turned around and headed home, died in my cul-da-sac. approx. 1/2 mile from home. I have drained the tank and the filter inside tank is fine. 3000 mile
any thoughts?
looks like there may be an in line filter, next in fuel system?
Joined: UTC Posts: 4204 Location: Twin Cities, Minnesota
Ever checked the valve clearances?
FLY 150
FLY 150
Hadn't considered internal issues since it runs fine, when running . but I can look into measuring that.
GT 2.4
Joined: UTC Posts: 8794 Location: Watts, Cherokee Nation
GT 2.4
And off they send you down the usual rabbit holes.
The odds are that you have a problem with either a spark plug cap that is falling off, the clip in the cap is broken and it's not staying on the plug, the top of your spark plug is broken, or there is a crack in a vacuum line.
Before you check the laundry list of things it can't be, or it wouldn't run, go through the ones that are known to give piaggio scooters problems.
Make sure there is a pin hole in the gas cap. If there's not one, put it there.
If you just changed the spark plug, that could also be suspect. Also, check the intake manifold to make sure it hasn't cracked.
Niether Seafoam nor an oil change is going to fix this, so save that, and replacing the air filter, until you get it running again. ,
