attaching cowl rubber rivet?
Fri Oct 25, 2019 3:18 pm quote
Any advice for how to attach the "button head" split rivet that holds cowl rubber to the rear of the cowl? I was thinking of vise grips? I punched a hole through the rubber trim but am wondering of the best way to fold the tabs of the rivet down. (I assume that is the idea, kind of like a cotter pin???).
Sat Oct 26, 2019 2:25 pm quote
Ok, here's the rivet in question:
https://www.scooterwest.com/button-head-rivet-for-attaching-cowl-rubber-to-cowl-and-seat-badge.html
I went to Menards and looked at their rivet section and couldn't see anything that looked like a proper tool for this thing.
'09 250 GTSie '75 Rally 200 '79 P200 '09 Stella 221
Sat Oct 26, 2019 2:35 pm quote
I think I've used a regular aluminum pop rivet
P200E
Sun Oct 27, 2019 12:41 pm quote
Seems like the best option, grab the tool and a case of rivets on the cheap and will last you forever. Throw a small washer on the rubber side to help keep it from ripping out.
Mon Oct 28, 2019 9:09 am quote
Thanks all, pop-rivet gun and rivets is one the way.
1979 P150X, 1983 P200E, 1987 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Mon Oct 28, 2019 9:22 am quote
I use these type of button rivets...
Mon Oct 28, 2019 9:45 am quote
For the split type I used needle nose pliers to bend each tab out.
Sat Nov 02, 2019 8:02 am quote
Thanks for the tips. I bought a Metakoo pop rivet gun ($23) from Amazon.
Worked great. Rivets were only long enough to go through one side of the cowl rubber, but that's fine. It came with enough rivets to last me a lifetime of cowl rubber replacement.
Rallies Europe 2016   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.3259s ][ Queries: 27 (0.0583s) ][ Debug on ]
