1971 Sprint
Post Reply    Forum -> Not-So-Modern 1234Next
1986 T5, 1971 Sprint
Sat Nov 02, 2019 9:51 am quote
I needed a winter project and I found this 1971 Sprint, itís in rough shape but it starts. The title says 1971, the engine serial number says it is from a 1974 Sprint Veloce.
No keys, engine cowl pin is missing, a few dings and some surface rust, and a broken center stand.
I plan to check the compression, replace the bearings, seals, clutch, shocks, engine mounts, brakes, tires, center stand, try to replace the locks, and see if I can get the autolube to work again.
Sat Nov 02, 2019 9:55 am quote
Nice score! Is that a a tuna can light? More Pics!
Sat Nov 02, 2019 1:04 pm quote
71 Sprint
Here's a few pictures of the Sprint, the scooter is not a Veloce, but the lump is, I rechecked the motor number and it is from a 74 veloce. The ignition switch is some sort of barrel lock near the fuel tap, (no key) I haven't found one online yet.
Sat Nov 02, 2019 1:29 pm quote
Sweet!
Sat Nov 02, 2019 5:05 pm quote
Great find! Looks like that Sprint had the infamous silver that peeled offed easy and someone painted it white. If you take the white off beware that you will find some bare metal where the silver peeled off.
Of course that barrel lock ignition was added. Did you check the exhaust bolt to verify it was a Veloce?
You've found a very nice scooter. Congratulations!
63 Lambretta LI 125 series 3, 71 Sprint Veloce , 2005 Vespa PX150, 1979 P200E
Sun Nov 03, 2019 9:47 am quote
I have a 71 Sprint Veloce, mine was imported. I can see that your scooter had bit and pieces from other scooters but overall it looks good.
Mon Nov 04, 2019 9:55 am quote
Motor is out, the wiring looks pretty good, the rubber bits and cables not so good. Iím making a list of parts to order.
Dirty motor
P200E
Mon Nov 04, 2019 10:08 am quote
Looks like a good start 🤙 Whats the plans with the body? Just a clean and buff?
Mon Nov 04, 2019 10:40 am quote
The tail on the scooter is damaged and a cowl peg is broken off. Iím going to take it to a body shop and have those 2 things fixed.
Not sure about painting.
58 VB1T, 68 SS180, 81 100 Sport
Mon Nov 04, 2019 11:05 am quote
Nice find CONGRATS! Just brought it home and motor already out making progress. Way to get at it!
GTS300i - Lambretta S3 '62
Tue Nov 05, 2019 5:12 am quote
Looks like at some point (the hole next to the choke) a px-engine with autolube had been added.
http://www.vespalabs.org/wiki/vespa-101/engine/autolube
Tue Nov 05, 2019 5:22 am quote
Nope that is stock motor. US largeframe vespas came with autolube as standard equipment since the early seventies. It was an upgrade for other countries.
Wed Nov 06, 2019 10:05 am quote
Cowl rust
Today I removed the seat, gas/oil tank, and the battery side cowl from the Sprint.
The sight glass has been removed from the oil tank, and welded up. It looks like I can either find a new gas and oil tank combo or cover the sight glass hole in the frame and just add 2t oil to the gas myself. The gas and oil tanks were separate on my p200 but on the sprint they are welded together.
Seat needs recovered. I have an auto upholsterer nearby but not sure what he'd charge to do it. Haven't found seat cover on the interweb yet.
Battery side cowl is rusted pretty badly on the bottom. The remaining metal is pretty thin. Can I put a layer of fiberglass filler on it? Or do I need a new cowl?
I suppose I could buy a matching pair since the holder peg is broken off the engine side cowl anyway.
Rusty cowl.
Seat and pad.
Welded up oil tank
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Wed Nov 06, 2019 11:45 am quote
You should be able to get a seat cover at Mercato , but out of black now and only has blue & red. YUCK, call Dave and ask when he gets more black in. For your cowl, yes to fiberglass, but no to just filler. Just do like this and use a piece of fiberglass cloth cut to fit on the inside, and I think you'll like the result.
Also, you're gonna pull the headset and fork ANYWAY, right? If so, do it now and maybe try this?:
Sat Nov 09, 2019 7:11 am quote
I was reading the post from DD-VES, about 2 port vs 3 port sprint engines. I was curious about mine so I checked the exhaust bolt hole on the swing arm of my sprint and it didnít go through the swing arm. Uh-oh, so I pulled off head and cylinder and found 3 ports. Good news!
This week I pulled the headset and removed the floor runners, the rust isnít bad at all. Iíve got a lot of cleaning and paint removal to do before I take the frame to body shop.
Vespa
Sat Nov 09, 2019 7:25 am quote
looking good
Tue Nov 12, 2019 12:13 pm quote
I'm in the process of stripping down the Sprint for bead blasting and body work, then paint.
There's quite a bit of rust on the mudguard and glovebox side cowl. The engine side cowl is missing the rear peg.
I've looked at repops for sale on SIP, the cost is reasonable, but shipping might be expensive. Can I have the old ones fixed? Are the repops a better solution?
I may take the 3 pieces into a body shop tomorrow for an estimate.
Rusted bolt holes in mudguard
Peg torn out of engine side cowl
Bottom of glove side cowl rusted
Vespa
Tue Nov 12, 2019 12:29 pm quote
good work. Looks like lot of original grey paint still underneath the white layer. Some originalist are crying out loud. lol.
Tue Nov 12, 2019 12:32 pm quote
Looks like a great project!
There's other ways to fix the cowl peg. Some use bolts or a metal rod welded to the cowl. Some don't even weld and use nuts and washers to hold it on. If you need to order one from SIP go through a US dealer like Scooter Mercato for a flat shipping rate.
BTW, Did you do the hammer test on the rusted area. That cowl floor is suspect and the fender may not have enough good metal in that area to hold the bolts. You may need to find good used pieces or a repops which are not that bad if you get them from a respectable supplier and not Ebay. Hope you can save them.
Good luck!
Tue Nov 12, 2019 5:18 pm quote
Partial list of items I want from SIP.
Engine gasket set
Bearings
Seals
Rings
Engine mounts
Clutch rebuild kit
Road 2 exhaust
Cruciform
Rubber bits
SIP tubeless rims w/tires
Center stand
Seat cover
Seat cushion
Steering bearings
Carbone shocks
Mud guard
2 cowls
Various screws, nuts, floor mat, etc,
Shipping estimate is $95, not too bad.
Mon Nov 18, 2019 10:04 am quote
Iíve got the scooter nearly ready paint and rust removal. Still have some work to do on the head set.
Iím not sure whether to have it dipped or blasted. Iím waiting to hear back for a price from the Ďdipperí.
Mon Nov 18, 2019 11:39 am quote
the people who love dipping will talk about the sand coming out later, and the people who love blasting will talk about the chemicals coming out from the seams later .
Me - I'd probably get it blasted, and not look back, but I have no experience to speak of on this. One thing I can offer - years ago I had a friend with an auto body shop who helped me paint my 63 falcon. we didn't take the car to bare metal, we only sanded it all and used the original paint as the base, with primer on the areas of repair for metal, etc. it came out great. So no need to get every last bit of paint off the bike to have a good finished product, so long as the body work and primer phases get enough attention.
Thu Dec 12, 2019 11:47 am quote
The Sprint body is still at the dipper-stripper, they say it'll be ready next week. I got a gas tank from Voodoo, (thanks !) and started working on it today. (The old tank was buggered) I put some acetone in the tank along with some pennies, did a lot of shaking, checking, shaking, checking. I also attached some steel wool to the end of a long screwdriver which I dipped in solvent and used on problem areas. After rinsing the tank out and drying with a hair dryer, I'm pretty happy with how it turned out.
How do I get the tank ready for paint? I tried a heat gun and didn't make much progress. Should I use a paint stripper, or just sand it?
1963 VBB2T
Thu Dec 12, 2019 3:17 pm quote
The tank came out great, hows the rest of the frame going to be , any idea yet?
Thu Dec 12, 2019 5:20 pm quote
Break out the sander!
Thu Dec 12, 2019 5:23 pm quote
One of my friends bought a red 63 Falcon Futura convertible around 2005. Since i did all the maintance and work on it, i got to cruise around in it whenever i wanted! His car came with the V8 so it was pretty darn quick!
Sat Dec 14, 2019 4:18 pm quote
I finished paint removal on the gas tank. I used a disc sander, then a wire wheel on it. I tried hand sanding but that was slow going.
I think it came out okay, no reason (I know of) to do anything but the top of the tank.
Looking forward to getting the frame back from the dipper next week.
Iím hoping to clean up the motor and start the rebuild on that this week too. I have a parts list about a mile long, including a mudguard and both cowls. But I havenít ordered anything yet.
Sat Dec 14, 2019 4:30 pm quote
Make sure you discuss with the the dipper about neutralizing the acid...
Sat Dec 14, 2019 5:13 pm quote
Iím hoping to be able to spray the tunnel and the area beneath the fuel tank with a rust inhibitor. Or use a brush if I canít spray into the tunnel.
The dipper said they apply a rust inhibitor, but that it is only effective for 60 days. After I deal with the tunnel, Iíll take the scooter body and parts to an auto body shop for some body work and paint.
Fingers crossed, he did the cowls on my T5 and did a nice job.
Mon Dec 16, 2019 6:51 pm quote
Started cleaning and taking apart the motor on this old sprint. Spent 15 minutes removing a circlip from the flywheel only to realize the circlip is needed to remove the flywheel.
I'm looking at the stator and I think it's in good condition. The wiring insulation is brittle in spots, but the portion contained within the flywheel housing is okay. I am thinking I can splice new wires onto the ones coming out of the stator with connectors. Has anyone done this? It's cheaper than buying a new stator or having this one professionally rewired.
Mon Dec 16, 2019 7:44 pm quote
Its best to remove the entire wire from the stator and replace. Will need a soldering iron, ring connectors, and new wires with the correct color and guage. I've replaced wires on a P's points stator. Didn't look pretty but it worked. Got wires, multi-meter, and soldering iron kit from Amazon
If you're not comfortable with replacing the wires, Scooter Mercato offers a very good stator rebuild service at a very good price.
http://www.scootermercato.com/Garage/Vespa-Stator-Rewire
Mon Dec 16, 2019 8:04 pm quote
Agree with Rowdy, replace the whole wire. ScooterWest has wiring kits and it is easily done. One wire at a time. I'm going to be doing the same thing to my 66 Sprint in a few weeks. And the service at Scooter Mercado is always an option.
Mon Dec 16, 2019 8:20 pm quote
I fog the absolute heck out of the tunnel whenever I spray a scooter. Turn the spray fan down to a point, turn up the air pressure, and let it rip! If you get REAL good fog of paint down in that area, you should have good coverage on all the bare metal. Thatís the one area I consider totally acceptable (maybe even required?) to get runs and sags.
Mon Dec 16, 2019 8:32 pm quote
by the way, the tank came out great!
bare metal cafe racer
Mon Dec 16, 2019 10:38 pm quote
Just saw your tank. Snap! This is clear coated...
Btw... Penetrol is awesome as a rust inhibitor - and will get into the seams and places spray paint canít.
1963 VBB2T
Tue Dec 17, 2019 5:47 am quote
So early in the morning and learned something new already, never thought of being able to lower the fan to a point and get into those deep dark areas, good tip.
The tank came out fantastic.
Wed Dec 18, 2019 9:02 am quote
The scooter body is back from the stripper, looks like it needs more body work than I thought, but all in all not bad! I'm hoping to spray a rust inhibitor into the tunnel before I take the scooter to a body shop for body work and paint.
I also split the engine cases and they look fine, (that took a while) the piston and cylinder look good too, it's a 74 Veloce 150 motor. I plan to rebuild the clutch and Cush drive, clean up the cylinder, put on new rings, also seals and bearings.
I cleaned up the floor rails and look okay too.
Time to order parts
The crank is stuck into the flywheel side bearing or seal.
Vespa
Wed Dec 18, 2019 9:45 am quote
darn that turned out super duper clean! I bet it will be a pleasure whoever gets to put color on it.
Wed Dec 18, 2019 7:47 pm quote
Ordered parts today.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.2074s ][ Queries: 25 (0.0463s) ][ Debug on ]
