LX150 noise and smell
GTS 300 SS, LX150, Stella 150
Sun Nov 03, 2019 3:10 pm quote
I replaced the stock rollers with Dr. Pulley 8.5g about 150 miles ago. Initially it ran really smooth, no noise etc. Now I'm getting a weird noise that comes on at about 35mph or say when I let off the throttle at low cruising speed. Once I stop and shut off the scoot there's a weird smell. Not sure if I got defective rollers? I made sure that they went in the correct way.
Wondering if anyone on here has had similar luck with Dr. Pulley sliders?
Thanks!
GTS 250ie Super, Italjet Velocifero, Scarabeo 150, S50,ET4
Mon Nov 04, 2019 5:56 am quote
What did you find when you opened the CVT?
Mon Nov 04, 2019 6:19 am quote
Opening the CVT today.
Mon Nov 04, 2019 12:00 pm quote
Mon Nov 04, 2019 1:09 pm quote
Smell? What does it smell like? Burning rubber? Oil? Gasoline? Wet dog? Rollers don't smell, and those Dr. Pulleys look all right.
What does the rest of the CVT look like? Belt? (How long since it's been changed?) Dust in the CVT air filter? Oil or grease in the case? Burned clutch pads? (Clean the clutch bell while you're in there.)
Mon Nov 04, 2019 5:14 pm quote
I'd say the smell is closest to a burning rubber of some sort. Thanks for verifying the sliders are in right.
I replaced the belt 150miles ago so that's new. CVT air filter was replaced but when I replaced it there was oil in the case. I cleaned the clutch bell and pads while I had it apart.
Tue Nov 05, 2019 8:36 am quote
The only rubber in there is the belt and some small o-rings and seals in the clutch. Does the belt show signs of wear? Is the clutch operating normally? It could be binding on the belt.
Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956 - Yamaha Majesty 250 DX 1998
Tue Nov 05, 2019 8:49 am quote
Have you lubricated the rollers with the appropriate grease?
Tue Nov 05, 2019 9:03 am quote
Attila - I didn't realize the sliders needed grease. If so what kind?
Pinkscooter - The new belt shows no signs of wear.
Thanks!!
Tue Nov 05, 2019 10:00 am quote
I do not think grease of any kind is required anywhere within the variator cover (especially rollers and belt).
Tue Nov 05, 2019 10:13 am quote
Yeah seems like it would make a royal mess!
Primavera ET3 & PX150 & GTS 300
Tue Nov 05, 2019 10:16 am quote
Check your oil level. Your belt could be coming out too far, rubbing against the case and burning away the oil gasket.
Tue Nov 05, 2019 10:31 am quote
Checked oil level and seems fine - hard to read on the dipstick IMO. The motor was warm when I checked it and the smell was different than the other smell. I did replace the clutch spring to white. Wonder if itís too much?
Wed Nov 06, 2019 10:38 am quote
My speculative guess would be that -- when the variator was reassembled after installing the Dr. Pulleys -- the thin spacer washers on the crankshaft were replaced in the wrong order or in the wrong position (or omitted altogether). This might cause the belt to ride higher than normal in the driving pulley when the weights are at their maximum outward extension at the highest engine rpm.
If the belt rides too high in the driving pulley, it may well rub on the inside of the transmission case as others have suggested... producing the burnt rubber smell and the noise. If this is happening, the rub marks should be visible below the variator pulley.
Such rubbing could also be caused by using a new non-OEM drive belt that is slightly wider than spec. That belt you put in 150 miles ago may be the problem. I doubt that a stronger clutch spring would cause it, as that should increase belt tension slightly.
Wed Nov 06, 2019 11:55 am quote
Spot on assessment. When reassembling the CVT I noticed one of the two shims was bore out in the middle so I didn't bother replacing it. I used the other shim washer in its place but I now have a feeling it might not be doing the trick. I'm assuming thats what could be causing the issue?
The belt I used is original Piaggio.
Just called ScooterWest and ordered the 2 shims. Wont ride the scoot again till I have it all together. Thanks again!!!
Sat Nov 16, 2019 5:18 am quote
Quick update - ended up installing doubling up washers on the inner variator side and the noise has gone away. The smell is still there but assuming its just a matter of time?
GTS 250, LX 50, and Falcon 200
Sat Nov 16, 2019 4:31 pm quote
What? No grease please. Final.
LX190, Primavera
Sat Nov 16, 2019 6:54 pm quote
Whats with all the scratching?
Sun Nov 17, 2019 2:39 pm quote
Scuffed it with 220 grit sandpaper.
Sponsor
Granturismo 218
Sun Nov 17, 2019 8:54 pm quote
If the smell is still there, it definitely is just a matter of time. The problem is that you've got something that is definitely wrong, but you've done so many unorthodox things, that it's hard to figure out exactly what's wrong. After this belt shreds, the best thing to do would be to set it back like it came out of the factory, ride it a bit, make sure it's right, and then put in sliders, if you are determined to use them. When the belt goes, even before you open the case, you would do well to order another outer variator plate along with the new belt.
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1696s ][ Queries: 25 (0.0280s) ][ Debug on ]
