PX125 Gear EFL and Later
Vespa 152l2
Wed Nov 06, 2019 1:31 am quote
I bought an engine and having taken it apart I'm told the layshaft is correct for the EFL casings (84-97), but the gears and matching gear cluster are from a later engine.
It is ok to use these in the EFL casing? Or do I have to obtain some period correct gears & cluster?
Wed Nov 06, 2019 2:25 am quote
Somebody might correct me here, but I was pretty sure that EFL were the last ones used. Measure them against this below (I believe Lusso and EFL basically mean the same thing when it comes to gears).
Also check your drive shaft. If it has circlips at either end of the gear stack, then it's the later EFL type.
1979 P150X, 1983 P200E, 1987 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Wed Nov 06, 2019 4:22 am quote
Correct. EFL = Latest...
Vespa 152l2
Wed Nov 06, 2019 5:47 am quote
Thanks I'll check on this.
Wed Nov 06, 2019 7:09 am quote
and remember, an EFL transmission can be used in the older non-EFL cases and vice-versa, a non-EFL transmission can be used in an EFL case. But what you can't do is mix and match the individual ELF and non-EFL transmission components with each other in the engine cases.
Wed Nov 06, 2019 7:50 am quote
Doing some work on this myself currently...
Last two pages have some images and explanation that may be helpful - as I was untangling it myself.
Vintage vespa with sidecar (Page 21)
Also - here is an exploded view that shows the components.
https://www.scooter-center.com/en/vespa-piaggio-px-125-e-fl-zapm09302-2001/exploded-views/gears
If you want to post some pics of your components - we could probably help you readily identify.
Good luck with your project!
- CM
Vespa 152l2
Sun Nov 17, 2019 12:58 pm quote
If I'm using EFL gears and cluster in a PX mk 1 engine do I need an early or EFL wheel layshaft?
Sun Nov 17, 2019 3:11 pm quote
The simple way to look at it is that an EFL gearbox must has all EFL parts from layshaft, gear changer, gears, and etc. An early gearbox has all early parts from layshaft, gear changer, gears, and etc.
You need a EFL layshaft.
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1539s ][ Queries: 27 (0.0274s) ][ Debug on ]
