This is a used diagnostics tool for Vespa and Piaggio fuel injected scooters. I bought it from ScooterWest this past summer to diagnose an issue and no longer need it. Just plug it into the diagnostic port on the Scooter, then the battery, and then connect the other end into your computer. It includes the card that shows you where to download the software. It worked great to read the error codes, check temperature, and test fans. I also used it to check the idle. See the description below from when I bought it. Asking $200 with Paypal. I'll pay fees and shipping in the continental US.
MIU Diagnostic Scan Tool and Software. Complete package to hook up your GTS to a USB port on Windows PC computers.
This Tool is capable of functions such as:
-Activate the injector, coil, or cooling fan for testing.
-Running parameters can be monitored and data logged.
-Stored errors can be read and erased.
-TPS can be re-zeroed
-Self-learning parameters can be reset.
Fix error codes and check out many other systems on your GTS via your home computer or laptop. A fun tool to have for anyone who owns a Vespa 2006-2014 GTS 125ie GTS250ie, GTS300ie, GT60, GTV Super 300 Vespa LX/S 125-150 ie. Also works with all 2008 and newer Piaggio injected scooters (Some BV 500, Aprilia Atlantic 500, Scarabeo 500 and other Piaggio injected scooters with MIU system), there is also a tool for the P15 injector systems on 2007 and earlier Piaggio scooters. All cables, software and instructions are included (computer not included).
Works with:
Vespa LX//LXV/S150 Fuel Injected 2010-2016
Vespa GTS/GTV/Super 250 300 2006-2019
Vespa 946 2013 to Current
Piaggio BV250/BV300 Fuel Injected 2008-2012
Piaggio BV350 2013-Current
Piaggio Fly 150 2011-Current
Piaggio MP3 250 400 500 2007-2010
Aprilia 250cc Scooter with MIU Injection
This diagnostic tool will retrieve codes associated with the engine ECU only. It will not retrieve diagnostic codes that are associated with the tilt lock ECU on MP3 250/400/500.
Must be FUEL-INJECTED with the THROTTLE BODY ON THE ENGINE.
Will not work on the 2020 HPE GTS.
