bleeding tilt lock
Red Mp 3 500
Sat Nov 16, 2019 1:56 pm quote
got a new pressure sensor for the tiltlock. Old one leaking. Know I am to bleed from bottom up. can not find any place to bleed from. Help. anyone know how to bleed the system, and where a nipple would be at to bleed from bottom up
2009 MP3 400
Sat Nov 16, 2019 3:21 pm quote
Halfway down each front strut there is a doohicky that the shiny rod passes through. There is a regular type bleed screw there, You'll have to do both sides.
Red Mp 3 500
Mon Nov 18, 2019 5:04 am quote
so that is for the tilt lock and not the brakes. thanks
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Mon Nov 18, 2019 10:09 am quote
Ahh... YeaAhh....
The Bleed Screws for the Brakes are on the Brake Cylinders which are different.
Look real close and you will see...
Use the Tilt-Lock switch to push the fluid through, then fill, and do again.
or...
You push fluid from the bottom, to the top...
Keith,
Marietta, GA
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.2381s ][ Queries: 25 (0.0448s) ][ Debug on ]
