Cutting OUT Vespa 300cc.
300 Super Sport
Sun Nov 24, 2019 5:02 am quote
I have a 2014 GTS 300 Super Sport. it has recently started cutting out. This happens at any time. Particularly scary at 120Km down the highway.
It just goes dead!!! It has been to the dealer twice, in fact got it back today and they say can't find anything wrong!!! STILL CUTS OUT.
40000Km on the clock. It is my daily commute.
Any help would be appreciated.
Sun Nov 24, 2019 5:53 am quote
dead in what way no elctrics or just cuts out.
if just cuts out intermittent fuel pump fault, blocked breather on petrol cap. something in tank being sucked onto filter. just some thoughts
300 Super Sport
Sun Nov 24, 2019 6:30 am quote
It is just cutting out. I really donít know. Have cleaned everything Electical with contact cleaner. New plug , new plug cap. Yesterday no cutting out. Today at least 12 times. At any speed. I donít know weíre or if thereís a fuel filter on the machine.
Sun Nov 24, 2019 9:52 am quote
If the dealer can't figure it out, perhaps it's time to find another mechanic or shop. These machines are not as simple as they used to be as they are computer driven. You can work thru this on your own if you have the time, but you would have to figure out if it is spark or fuel that is cutting out. Sorry I can't be of more help.
2009 GTS 250 "Noa"
Sun Nov 24, 2019 12:18 pm quote
Wiggle the fuel injector and connector when its idling and see if it hesitates or stalls.
eeee-bip
Benelli TNT 125/Kymco AK550 I don't care. You can quote me.
Sun Nov 24, 2019 12:25 pm quote
Clatter
Some in the UK had a problem with Stator that would make the scooter cut our without any warning.
Check that.
Bill x
GTS 300
Sun Nov 24, 2019 3:01 pm quote
As mentioned
The connector should not wiggle.
My wifeís 250 had a cutting out problem Ė the fuel injector connector that attaches to the injector itself was loose and other wise broken, it wiggled, on my scooter with the same injector it was firm. Replaced the injector, expensive $100, corrected the problem.
300 Super Sport
Sun Nov 24, 2019 8:29 pm quote
Thanks all
300 Super Sport
Sun Nov 24, 2019 9:40 pm quote
OK the story continues. Would not start this morning! Turn key on all the electrics come on, but will not turn over DEAD!
Turned key on and off and after a few attempts it started.
On the highway to work this morning it did not cut out???
Sun Nov 24, 2019 10:26 pm quote
Check the brake switches
2016 Vespa GTS 300 i.e. ABS, 2010 Vespa GTS 300 ie Super (sold) & 2003 Honda Shadow VT750 ACE (sold) & 2006 Vespa LX150 (sold)
Mon Nov 25, 2019 4:18 am quote
Had that problem with my 2010 GTS when it had ~30k kms on the clock. Took the dealer several attempts to get a fault to show up in diagnostics. Turned out to be the fuel injector. Put in a new one, problem solved.
2015 Vespa GTS300 Super
Tue Nov 26, 2019 2:43 am quote
I can imagine, as your GTS is your daily driver, that this intermittent starting/cutting out problem must be rather inconvenient. I had an intermittent starting issue with my 2015 GTS (thankfully it never cut out while running). In the end, a new throttle body/ECU solved the problem. I was able to get error codes using the techniques in the forum topic below, but the delivery and setup of the equipment takes awhile (I was on vacation at the time). If you work and are pressed for time, a dealer with the Piaggio PADS system may be able to help.
DIY Diagnostic tool for injection Vespa's with MIU ECU
GTS 300, BV 500, Buddy 125
Tue Nov 26, 2019 8:47 pm quote
Add me to the cracked fuel injector causing engine to shut off randomly list on my 2006 GTS 250
GTS 250i.e.
Wed Nov 27, 2019 12:48 am quote
Could be a duff kill switch.
63 GS160 / GT60 (X2)/ ET4 (X2)/ ET2/ 78 P200/ 67 Sprint/ 09 GTS/ 03 Ruckus/ 13 946/ 16 Prima 70/ 15 Sprint
Wed Nov 27, 2019 6:41 am quote
Kill switch
Fuel injector
Bad daily key.
Have you tried the master key?
SDG
Wed Nov 27, 2019 8:52 am quote
SDG wrote:
Kill switch
Fuel injector
Bad daily key.
SDG
Surely the key RFID is only needed to start the bike? The ECU stops looking for it once the engine is running.
Wed Nov 27, 2019 2:19 pm quote
jimc wrote:
SDG wrote:
Kill switch
Fuel injector
Bad daily key.
SDG
Based on my samples not necessarily. Daily key can be a menace sometimes, we call it corrupted.
SDG
Wed Nov 27, 2019 2:27 pm quote
Check Spark plug wire too. Especially the end at the plug.
Wiggle that but donít shock yourself.
300 Super Sport
Mon Dec 02, 2019 8:26 am quote
Thanks all for your generous feedback. The scooter is now at the Vespa dealership. The have kindly loaned me a 2020 Vespa 300. I await there findings
Mon Dec 02, 2019 12:16 pm quote
Make sure to look at the injector connector also. I had one the pins where spread to far to make good contact all the time.
2006 LX 50
Thu Dec 05, 2019 8:09 am quote
I doubt a fuel injector will prevent the engine from cranking. I suggest bypassing the kill switch. Or do you not have kill switches in your region?
Scooter Pimp
------Piaggio Zip 100------
Thu Dec 12, 2019 12:11 pm quote
What was the problem in the end?
'15 Blue GTS300 Super, '18 White GTS300 Super
Thu Dec 12, 2019 1:05 pm quote
Tell the shop to try swapping out the ECU with one of the other scoots in their shop. It is easy to do and reprogram using the master key.
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1416s ][ Queries: 25 (0.0321s) ][ Debug on ]
